Author Topic: Sheared bolt in the clutch pressure plate  (Read 8869 times)
Offline Drew400
  • 400/4 I restored
« on: November 15, 2014, 01:19:02 PM »
Yes indeed, folks. There I am 'tightening fully' (as instructed by Haynes) the four bolts that compress the springs/square plate of the clutch when, snap, one shears off. Oh joy, I say to myself as I briefly contemplate trying to run it with three bolts in place (soon dismissed that lazy notion).
I had already checked to see if there was a torque setting for these bolts when coming across the 'tighten fully' instruction. That instruction says to me, keep going until it stops turning... not a question of trying to then over-tighten it against the stop. No, this bolt snapped before I had to put any real pressure on it with a wrench.
I'm sure that I can source a new pressure plate fairly easily, probably more easily that trying to drill out the bit that's still in there. More importantly, do you have any tips for the torque that should be applied? Is there any danger from under-tightening (which will now be my preferred default approach)?
Thank you,
D.
Offline LesterPiglet
  • 1977 CB550F2
Re: Sheared bolt in the clutch pressure plate
« Reply #1 on: November 15, 2014, 01:34:50 PM »
I normally just tighten until they seat then a tiny nip-up.
Offline Drew400
  • 400/4 I restored
« Reply #2 on: November 15, 2014, 04:22:41 PM »
Thanks Lester,
That's what I though I was doing. Maybe there was a weakness in the bolt.
Cheers, D.
Offline RGP750
« Reply #3 on: November 15, 2014, 04:30:28 PM »
Quick tip that may get the broken part out.
Drilll about a 2.5mm hole in the centre of the broken part and tap
in a torx bit that is a tight fit, and use a socket on the torx.
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Offline Drew400
  • 400/4 I restored
« Reply #4 on: November 15, 2014, 04:56:42 PM »
Nice one RGP... and now I know what those strange little screwdriver bit things are called!
Cheers, D.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #5 on: November 16, 2014, 06:18:33 AM »
Hi Drew,
Does indeed sound like you had a 'tired' bolt. Time to replace all 4 perhaps?
If wanting to improve the tool inventory the (typical) screw extractor kit may be an option.. just depends on how many more jobs your planning!
http://www.ebay.co.uk/itm/8-Piece-Screw-Extractor-Broken-Stud-Damaged-Bolt-Remover-Set-Easy-Out-Brand-New-/110868152075
As you say, finding a torque for the 4 bolts is not easy... the 1st below is for the 750K2 lock nut.
The 2nd pic is for 'generic' bolts from my 750K2 manual... the 4 clutch bolts are 6x20 and the same part # as the K2
Good luck,
Simon
« Last Edit: November 16, 2014, 06:42:08 AM by Lobo »
Offline Drew400
  • 400/4 I restored
« Reply #6 on: November 16, 2014, 09:24:37 AM »
Thanks Lobo,
I may be investing soon and certainly will use a set of new bolts.
Cheers,
D.
Offline Drew400
  • 400/4 I restored
« Reply #7 on: November 16, 2014, 03:02:21 PM »
Update... the offending bolt is out. Was very easy and thus confirmed that I hadn't over-tightened it or else it would have been jammed at the bottom of its chamber.
So, I'm now asking DS if they have a set of new ones and will only tighten them to Lobo's generic suggestion.
Only a slight delay to my project progress.
Cheers all.
D.
« Reply #8 on: November 16, 2014, 03:32:12 PM »
Wel done getting them out Drew, big sigh of relief I'll bet! If all you want is those bolts from DSS, by the time you've added p+p and vat on the lot, it'll be expensive! Try a local hardware store,or even the Robin B'Stards at B&Q, theyre are just normal M6 bolts, 20mm long, easy to find, and cheap!:))
Sent from my GT-S5839i using Tapatalk 2
Offline Drew400
  • 400/4 I restored
« Reply #10 on: November 16, 2014, 05:15:53 PM »
And there's me thinking they're special Honda bolts.
Thanks chaps, all ordered.
D.
« Reply #11 on: November 16, 2014, 05:19:45 PM »
Yes, they are a special Honda bolt. It comes in a Honda bag from DSS and that is what you pay for ;)
Offline Drew400
  • 400/4 I restored
« Reply #12 on: November 17, 2014, 08:41:26 AM »
 :D
