Author Topic: Should the kickstarter work at this stage of the rebuild?  (Read 5284 times)
Offline Drew400
  • 400/4 I restored
« on: November 15, 2014, 03:11:15 PM »
Hello experts,
The engine is back together and the barrels, head etc. are fitted (see picture).
I attached the kickstart lever to see what happens when moved by hand. All that happens is the clutch centre shaft rotates. Should it not also turn the crankshaft and the pistons?
I'm hoping with fingers crossed that the clutch etc has to be in place to make this all work, rather than I have cocked something else up and have to dismantle the whole thing again for the umpteenth time!
Thank you (in worried but hopeful anticipation).
D.
Re: Should the kickstarter work at this stage of the rebuild?
« Reply #1 on: November 15, 2014, 04:14:09 PM »
Drew,
As far as I can remember yes the clutch etc needs to be assembled.
Regards,
Offline Drew400
  • 400/4 I restored
« Reply #2 on: November 15, 2014, 04:21:45 PM »
Ta, Paul.
Hope rises.
Cheers, D.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #3 on: November 16, 2014, 06:44:44 AM »
Hi Drew,
A description from the 750K2 manual... I think fairly similar to the 400F 'workings'... Bryan, OddJob etc to correct me if wrong.
Simon
Offline tom400f
« Reply #4 on: November 16, 2014, 09:09:28 AM »
Drew,
The gist of it is that the kick start drives the engine back through the clutch.
Tom
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Offline Drew400
  • 400/4 I restored
« Reply #5 on: November 16, 2014, 09:21:40 AM »
Thank you all again.
I'll continue rebuilding with renewed confidence!
Cheers, D.
