Author Topic: Softening rubbers  (Read 3801 times)
Offline martin_uk
Softening rubbers
« on: November 17, 2014, 08:58:27 PM »
I see some people have used the boiling water and Winter green oil, but I didnt fancy it.
Found a tip to use Xylene and concentrated Winter Green oil mix.
 Winter green is the more expensive, but bought 500ml and 5ltr Xylene for about £30.
Not economic if you only have a a few rubbers to do, but as I have quite a few decided to give it a try.
You need to be quite careful in handling these chemicals and use recommended protective clothing, ventilation, gloves etc.
I mixed at ratio of about 5 parts Xylene to 1 part WG oil in a medium sized pickle jar with lid.
First tried on inlet rubbers.
The rubbers were rock hard, but swell up  after soaking for a day or too, but dont leave too long.
It seems to work by the Xylene swelling rubber and WG oil then soaking into rubber to maintain flexibility.
Took a while for xylene to evaporate off after removed from mix and rubbers returned to normal size and now quite pliable.
Then tried with a small batch of rubbers including the unobtainable CB750F1 rear seat cowl rubber buffers.
With many of small mounting rubbers at £3 odd each and some rubbers unobtainable, may be of interest.
If the rubber has perished and cracked, this method will not restore.
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
Re: Softening rubbers
« Reply #1 on: November 18, 2014, 11:03:24 PM »
Here is a pic of CB750F1 seat pan rubber, two I did earlier and  after a 1 day soak.
DSC_0242 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
