Author Topic: front pipe fork - chrome condition  (Read 14644 times)
Offline antonypo
  • wheres the breaks on these cb 750's !
« on: December 09, 2014, 02:02:22 PM »
After removing the gators to replace the fork seals on my usa k4 I noticed scouring on the chrome pipe forks. After further inspection and removing the cushion fork covers, I could see why.
Someone in the past had added a chrome washer underneath the circlip on each fork. As this did not belong it has moved about over the years and scoured the chrome.
My question is when do these become illegal to ride/use? As long as the new seals do their job is it ok to continue using them as at £260 each I don't want to replace if not necessary.
Secondly, can anyone tell me the correct way up for the new fork seals? Taking the old out destroyed them and other than a slight hump on one end they look exactly the same either way up.
Antony
Antony
Re: front pipe fork - chrome condition
« Reply #1 on: December 09, 2014, 03:11:39 PM »
Anthony
On the fork seal there is a spring type ring that goes at the bottom,as for the fork tubes as long as the seal don't leak they are fine.Mot ers might know different as been out of the UK for 14 years now and rules may have changed
Bitsa
« Reply #2 on: December 09, 2014, 04:44:30 PM »
Not sure were this washer is on your bike.
Forks will not pass a MOT if 1) they are bent 2) if they leak 3) if any mounts are broken 4) if they are not operating in the way they should.
Offline Green1
« Reply #3 on: December 09, 2014, 06:44:18 PM »
K1 forks have a washer after the fork seal before the circlip
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #4 on: December 09, 2014, 06:46:09 PM »
Mick
So do K0 and early K2 ;)
Offline Green1
« Reply #5 on: December 09, 2014, 06:48:06 PM »
You just looked that up smart ass
Mick
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #6 on: December 09, 2014, 07:10:52 PM »
Mick
Nope, i have a set of K0, K1 and K2 at Philpots which i took apart last week.
« Reply #7 on: December 09, 2014, 07:15:07 PM »
Trigs right after the k2 they did not fit the washer
Bitsa
« Reply #8 on: December 09, 2014, 07:57:17 PM »
What i am not understanding Antonypo. Is you say a chrome washer under the gators scouring the chrome pipe forks???
Not making sense of this washer. Are you saying that it is on the outside?
« Reply #9 on: December 09, 2014, 08:07:44 PM »
Agree Trig the washer was located on the top off the seal under the circlip.There is no way that it would run against the tube, the discolouring is down to old age like most of the old gits club ;) ;)
Bitsa
Offline Green1
« Reply #10 on: December 09, 2014, 08:16:00 PM »
When I bought mine the seal wasn't seated properly so the  circlip put a lovely gouge in the tube about an inch long.
Mick
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #11 on: December 09, 2014, 08:18:34 PM »
Mick
Good point Mick. I see what he means now.
Offline Green1
« Reply #12 on: December 09, 2014, 08:32:57 PM »
I think I took the washer out last time and replaced the seals with thicker ones.
Supposedly to make them last longer
Doesn't work as they have been weeping since I fitted them.
Mick
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #13 on: December 09, 2014, 08:43:05 PM »
Sorry guys they do not leak seap or whatever unless they are knackered sorry to be blunt and will say with caution the replicas are just fine.Bought some fitted them and for a member of the grumpy old gits club I seem to be happy with them will probably bite me in the arse later. ;) ;)
Bitsa
Offline Green1
« Reply #14 on: December 09, 2014, 08:52:46 PM »
Knowing me I probably overfilled them I always get confused when the amounts are in CC
Mick
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
