Author Topic: carburettor  (Read 12443 times)
Offline hondatri
Re: carburettor
« Reply #15 on: January 08, 2015, 03:59:01 PM »
 ok stupid question guys. I have made up a height measure 21mm for float level. With the carbs upside down do I measure at the furthest point from the valve end, Or am I doing it wrong,
Offline tom400f
Re: carburettor
« Reply #16 on: January 08, 2015, 04:18:54 PM »
You are measuring from the face of the carb body to the top (that is bottom) of the float. Make sure the weight of the float is not depressing the sprung pin.
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Offline Bodd
Re: carburettor
« Reply #17 on: January 08, 2015, 04:20:51 PM »
From the float bowl mating face to the highest part of the bottom of the float when the carb is inverted.
Offline hondatri
Re: carburettor
« Reply #18 on: January 08, 2015, 07:06:47 PM »
The 400/4 carb  float pivots at one end while the opposite end of the float is the highest point is this where I measure height.
Offline Bodd
Re: carburettor
« Reply #19 on: January 08, 2015, 07:18:10 PM »
Mine are pretty much parallel with the carb body/float bowl seating face as they should be. Not my picture but mine were pretty much like this, you need to bend the centre tang next to the pivot point to make them level.
« Last Edit: January 08, 2015, 07:21:52 PM by Bodd »
Offline Bodd
Re: carburettor
« Reply #20 on: January 08, 2015, 07:26:17 PM »
Bend the tang arrowed to get them level when in the rested position and they should be around 21mm, if they are tilted as you describe the 21mm dimension is the point on the float furthest from the carb body/float bowl seating face.
« Last Edit: January 08, 2015, 07:29:07 PM by Bodd »
Offline hondatri
Re: carburettor
« Reply #21 on: January 09, 2015, 10:01:18 AM »
 Thanks Bodd and all others who offered advice I now know what to do. All advice appreciated.
Offline Bodd
Re: carburettor
« Reply #22 on: January 09, 2015, 12:53:37 PM »
Another thing you need to get right is to make sure all the slides move/start at exactly the same time when the throttle is turned, also get the dimension in the picture below as near as possible when you put the carbs back on the bike, it's the best starting point for synchronisation, you can't get a vernier in so I made a 56mm gauge out of a nail.
Offline hondatri
Re: carburettor
« Reply #23 on: January 14, 2015, 04:09:48 PM »
Thanks Bodd for that very informative info.
