Try our re-instated info resource - "Aladdin's Cave" (Main menu)- sorry it's taken so long to fix
That's the one Julie means, SteveI bought 17335323000 from DSS - it has no pinch drain but since only the upper part was perished I used only that (or some such memory anyway). No idea why there is a "valve" in it at all. Perhaps to keep the crap out as there is likely no pressure or even some suction...
Quote from: Nurse Julie on January 02, 2015, 08:16:50 PMJust looked on DSS and the drain pipe from the air filter box with the pinch drain at the bottom is now an obsolete part. Does anyone know where else I can get this from?. Its Part No 17358-374-000. They still do the breather pipe from the bottom of the air inlet box which is handy as that's the one I'm missing completely.Juliemeasure the outlets and order Nitrile rubber smooth pipe
Quote from: Trigger on January 02, 2015, 08:25:03 PMQuote from: Nurse Julie on January 02, 2015, 08:16:50 PMJust looked on DSS and the drain pipe from the air filter box with the pinch drain at the bottom is now an obsolete part. Does anyone know where else I can get this from?. Its Part No 17358-374-000. They still do the breather pipe from the bottom of the air inlet box which is handy as that's the one I'm missing completely.Juliemeasure the outlets and order Nitrile rubber smooth pipe Hi TrigWe use Nitrile rubber pipe at work but I've got a feeling what we use is a lot larger bore. Do you think it matters if it does not have the valve in the bottom ?RegardsJulie
Oh OK. I remember wondering at the time because the nomenclature is ambiguous. Obviously I bought the wrong bit but... the pinch thing is separate and I reused the old one I had. It slips over the bottom of the tube, about 2cm long.Not saying these were ever separate parts but hey, it's just a blind bit of tubing with a cut in the end. Perhaps something could be made...
Quote from: tom400f on January 02, 2015, 09:28:41 PMOh OK. I remember wondering at the time because the nomenclature is ambiguous. Obviously I bought the wrong bit but... the pinch thing is separate and I reused the old one I had. It slips over the bottom of the tube, about 2cm long.Not saying these were ever separate parts but hey, it's just a blind bit of tubing with a cut in the end. Perhaps something could be made...Gosh, I never thought I would come across anyone else on this forum who knows about the 'ambiguity of nomenclature's '.You sound like my old Professor at Uni but he only rode a push bike, an old 1927 Dursley or something like that
Quote from: Nurse Julie on January 02, 2015, 09:38:21 PMQuote from: tom400f on January 02, 2015, 09:28:41 PMOh OK. I remember wondering at the time because the nomenclature is ambiguous. Obviously I bought the wrong bit but... the pinch thing is separate and I reused the old one I had. It slips over the bottom of the tube, about 2cm long.Not saying these were ever separate parts but hey, it's just a blind bit of tubing with a cut in the end. Perhaps something could be made...Gosh, I never thought I would come across anyone else on this forum who knows about the 'ambiguity of nomenclature's '.You sound like my old Professor at Uni but he only rode a push bike, an old 1927 Dursley or something like that What ever you do Julie, don't ask which way round the clutch cable eye goes. 400 Boy's can be a little sensitive
I previously had a 400/4 and tried to find the correct tube with pinch/duck bill type end.I seem to remember buying one from India for a Royal Enfield, but dont remember if it fitted.I believe the idea is that excessive pressure will open the duck bill, but if low pressure, will close bill and stop unfiltered air entering?What size is the outlet on breather trap?I will have a look to see if I still have.
