Author Topic: spark plugs cb550  (Read 6896 times)
Offline rickni
  • gettin there! it's always gettin there..
spark plugs cb550
« on: January 04, 2015, 10:40:55 PM »
Hello
What type of spark plugs suit this bike?
have cb550 k3 running keihin pd carbs originals to the bike,,
thanks
Offline Norniron
Re: spark plugs cb550
« Reply #1 on: January 04, 2015, 10:42:11 PM »
The ones I GAVE U
1977 400 cafe
1972 500/4
2013 triumph STR675
« Reply #2 on: January 05, 2015, 08:43:22 AM »
The ones i advised you to use  ;)
Offline rickni
« Reply #3 on: January 05, 2015, 12:39:21 PM »
Anybody got a cb550 running keihin pd carbs??
Gone tell me wat sparks ur runnin!!!! And is it runnin alright!!!!
Offline matthewmosse
« Reply #4 on: January 05, 2015, 08:10:29 PM »
I would personally suspect the carbs first, I always ran the plugs Dave Silvers sent out ( being dead lazy I just ring up, give bike reg no, have the parts they send , never do I do part numbers) in my k3 when it was running to no ill effect. I have had a few dud ngk plugs over the past few years where the spark seemed ok outside the cylinder but once run a few minutes the bike refused to run - new plug ( again) sorted it, or severe abraiding of the electodes - I never figured out the answer to why this was the case, but had it on several machines and with ngk plugs from several suppliers. Every time the plug seemed ok but refused to fire in the engine, re gapping - no efffect, swap plugs for new or known good, ran fine.
Offline andy_c101
  • Gone but not forgotten.....
« Reply #5 on: January 05, 2015, 08:29:52 PM »
rick
sent you a PM, one some of my experiences with K3 carbs.
Andy
Offline totty
« Reply #6 on: January 05, 2015, 08:37:59 PM »
What is the problem? The common flat spot around 5k or something else?
Regarding plugs I tend to use NGK iridium on all my bikes, no noticeable benefit when everything's right but I've never had a bad one, I've never had one foul even when the mixtures been well out and they last ages.
Offline peterengland
« Reply #7 on: January 06, 2015, 12:41:50 PM »
I have the same bike and carbs, I run D7's don't run DR7's though. You can use D8's but mine runs best on the 7
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
