Try our re-instated info resource - "Aladdin's Cave" (Main menu)- sorry it's taken so long to fix
Trig - update on jetting. New mains are 110's and pilots 40 (the ones I got from DS). Put clip on centre notch and will try that and go from there. Have dug old jets out and they where 100's.Carbs all back together and set up on bench as per manual. Will put them on and let you know how it runs.PhilPS - did I see a SOHC member post a thread recently that they are doing a full range of jets. Can't find thread now. Or has DS got genuine items at reasonable prices?
Just started it again and now needs choke and responds ok. I will strobe it and balance carbs before MOTing and road testing it (will wait till weather is better) - I'll get 120's sorted - any recommended sources for jets and your recommended foam filter. Hopefully will be sorted - feel that on std compression, I should be able to set up eventually.
Just spotted this - http://www.ebay.co.uk/itm/191425255660?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT - what do you think?
