Author Topic: Rear Shocks - advice please  (Read 10698 times)
« on: January 11, 2015, 11:26:03 AM »
Hi Chaps
I have Hagon shocks on this 400/4. On the nearside bottom fixing the PO has put 3 washers on to move the bolt out by a nano so the end of the bolt misses the nuts that hold the sprocket on. Should I also put a couple of washers on the fixing at the top of the shock, there is only 1 at the moment, so it brings the top out by a nano as well and should I do the same on the offside even though there is nothing for the bottom bolt to foul on ?
Ta in advance
Julie
Offline ka-ja
  • ken
  • yoshi 460
Re: Rear Shocks - advice please
« Reply #1 on: January 11, 2015, 11:50:15 AM »
Hi Julie,
           The PO washers were probably to make up for incorrect length bolts, the shocks should line up when fitted as per parts drawing.---Ken
           http://www.cmsnl.com/honda-cb400f-england_model14639/partslist/F01-4.html#results
« Last Edit: January 11, 2015, 12:15:35 PM by ka-ja »
nice bike,nothing in the bank
« Reply #2 on: January 11, 2015, 12:54:38 PM »
Thanks Ken. That makes sense, I will cut the end of the bolt off.
Thank you
« Reply #3 on: January 11, 2015, 03:13:48 PM »
I would not be cutting the bolt if it is the right length. what you may find is that the shock eyes are slimmer than the OEM, so the PO has put washers in to pack it out.
« Reply #4 on: January 11, 2015, 04:00:21 PM »
Ok, I won't cut it off then  ::) ::)
« Reply #5 on: January 11, 2015, 04:05:00 PM »
Somebody who has originals could be nice and measure the length of the bolt and the distance across the outside of the original fittings for you, unless 500 are the same I can't help there tho'
« Reply #6 on: January 11, 2015, 04:09:03 PM »
M10 x 32 on the bottom shock mount ;)
« Reply #7 on: January 11, 2015, 04:17:49 PM »
Do you actually measure the head of the bolt,(Sorry Chaps, never have known where to measure from), if you do mine are 10x43 ish, so too long. A 10x32, without the head,would be about 2 mm too short and that not alowing for a washer
« Reply #8 on: January 11, 2015, 04:23:05 PM »
That is a secret ;D
« Reply #9 on: January 11, 2015, 04:37:26 PM »
You and your bloody secrets Trig  ::) ::) ::)
« Reply #10 on: January 11, 2015, 06:17:20 PM »
Bolts are measured from under the head to the very end of thread
Offline Clem2112
  • Midlife
« Reply #11 on: January 11, 2015, 06:47:31 PM »
... And so are screws
« Reply #12 on: January 11, 2015, 06:50:00 PM »
And some numbnuts ;D
Bitsa
Offline tom400f
« Reply #13 on: January 11, 2015, 11:46:25 PM »
I'll have a squint at my standard shocks and report back tomorrow eve....
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
« Reply #14 on: January 12, 2015, 07:08:11 AM »
Mt nuts are neither numb nor measured mate!!!
