Author Topic: Rear Shocks - advice please  (Read 10750 times)
Offline martin_uk
Re: Rear Shocks - advice please
« Reply #15 on: January 12, 2015, 10:11:06 AM »
CMSNL show originals as M10 x 32
http://www.cmsnl.com/honda-cb400f-england_model14639/partslist/F01-4.html#results
Many of the fixings have dimensions shown in the parts details so quite handy.  The Honda part number also shows size.
Hagon may be different
Originals had a fine (1.25 thread pitch) normal M10 is 1.5
I would suggest shortening bolt rather than extra washesr, dont forget to file end to tidy and create lead in on threads (taper) but if existing are wrong size and the 32mm are correct on Hagon as well, new bolts are about £2 each from DSS and nice and shiny  :)
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
« Reply #16 on: January 12, 2015, 10:20:48 AM »
Thanks Martin.
Offline ka-ja
  • ken
  • yoshi 460
« Reply #17 on: January 12, 2015, 11:59:52 AM »
Hi,
    Fitted Hagons myself, along with their progressive front springs with no problems.The bottom yokes were the correct gap and thread as per originals, easy way is to try the bottom "yoke" for side play against the swinging arm bushes, and try the fixing bolt before finally putting it vall together!----Ken
nice bike,nothing in the bank
« Reply #18 on: January 12, 2015, 12:24:35 PM »
The bottom yokes of the shocks are a perfect fit actually at the fixing point, no side play at all. I think I will either cut the bolts down or buy some M10x32
« Reply #19 on: January 12, 2015, 12:56:35 PM »
I can not be 100% sure because my 400 is in storage but, the 550 and 750 have a chrome bolt for the bottom shock mount.
Offline Clem2112
  • Midlife
« Reply #20 on: January 12, 2015, 02:14:57 PM »
Buy stainless bolts and polish the heads  - probably cheaper than the Honda OE ones.
Offline tom400f
« Reply #21 on: January 12, 2015, 10:20:49 PM »
Std shocks Julie. May be of some use
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
« Reply #22 on: January 13, 2015, 06:49:58 AM »
Thanks Tom. They look the same size as my Hagons, I think I'm just going to go with a shorter bolts.
Thanks again
