Author Topic: Bloody brakes!  (Read 3975 times)
Bloody brakes!
« on: January 18, 2015, 08:37:09 PM »
Trying to get some pressure at the lever for the last few weeks.  Had pressure but back to the lever - essentially don't brake the bike!
Tried all tips - tapping lever/caliper, bleeding at every junction, lifting the caliper to highest point, etc, Tried back filling with a sringe but will not force fluid up line (with lever held in) - sringe solid. Same when I try to push the piston back.
I now can't any pressure!
This has made me doubt my master cylinder rebuild!
I've stripped the master cylinder now. The cylinder has 2 holes in the bottom of the reservoir but 1 is blind while the other goes through to the cylinder. (When I shine a torch down the cylinder, I can see the 1 hole).
Question is - should both hole go through to the cylinder. I'm asking in case one's blocked (as I say, when I look down the cylinder, there doesn't seem to be a hole that side).
I'm grasping at straws I know but getting desperate.
Offline LesterPiglet
  • 1977 CB550F2
Re: Bloody brakes!
« Reply #1 on: January 18, 2015, 08:54:02 PM »
Yes. It's blocked. 1 hole in the MC is tiny. It needs poked with a strand of wire brush or something that fits the hole.
Re: Bloody brakes!
« Reply #2 on: January 18, 2015, 09:08:43 PM »
if you back bleed,don't hold the lever in,
fill the caliper(s) and connect the pipes ,then press the piston in and force the fluid up to the MS,
normally works 99%
Re: Bloody brakes!
« Reply #3 on: January 18, 2015, 09:38:44 PM »
Thanks - tiny hole was blocked and just cleared it with 1mm drill. Hopefully will be able to get pressure! Will try tomorrow night as been on it for 3 hours today
Thanks guys
Re: Bloody brakes!
« Reply #4 on: January 18, 2015, 09:42:21 PM »
It is better to blow them out with a airline ;)
Re: Bloody brakes!
« Reply #5 on: January 19, 2015, 09:14:52 PM »
With that little hole unblocked, brakes bleed with great lever pressure within 5 mins! Another lesson learned
