Author Topic: White deposits in carbs from Ultra Sonic cleaner  (Read 24288 times)
« on: February 02, 2015, 11:57:49 AM »
Hi All.
Just picked up my carbs from the cleaners. Cleaned in a big ultra sonic cleaner with some carb cleaner added. On the whole the carbs look alot cleaner generally but I seem to have what looks like Calcium deposits in some areas. Mainly where the choke flaps are and on the flaps. Also some very small areas of white stuff in some of the outer body nooks and crannies. Now, it seems easy to remove the stuff on the outside but what do I do about the rest and how do I know the internals are not full of this crud as well?. I had removed and will be replacing with new, all the jets that usually hang down in to the bowls so they won't be a problem, but what about everything else inside ?. Should I take the carbs apart from the top as well and check everything ?.Apologies if my explanation's are not too good.
Ta in advance
Julie
Re: White deposits in carbs from Ultra Sonic cleaner
« Reply #1 on: February 02, 2015, 12:09:42 PM »
Hi Julie
You are really going for it arent you? ;)Photos would help though of this crud
All the best
Ralph
Offline PatM
« Reply #2 on: February 02, 2015, 12:10:25 PM »
That's a bugger- but to be honest- air makes carbs oxidise- that what happens to bare ally. Ive never had carbs cleaned by an ultra sonic process but some folks speak highly of it. Im too tight or cant be arsed- mixture of both. I suffer carb cleaner and an airline. Id clean the obvious off with a toothbrush and some wd40 and fit then/fire it up.
« Reply #3 on: February 02, 2015, 12:14:23 PM »
Funny .. Five minutes ago  I have just put a carb. body from a CB750,  that I am giving to elBurro on here,  into the US cleaner with some new additive I just got from Allendale electronics that is supposed to be suitable for carbs and non- ferrous in general. They are in there at 55°C with the solution (they recommend a 10% solution at 50 ->60 °C. It's a big industrial US cleaner and will give you an appraisal in a couple of hours. The carb body has  the white oxide on the inside, as you describe Julie.
Ash
« Last Edit: February 02, 2015, 12:17:05 PM by AshimotoK0 »
« Reply #4 on: February 02, 2015, 12:14:35 PM »
Pat
I had some here done and to be honest was not impressed ran like a bag of spanners so stripped again and did it your way much better results.
Wont be going sonic way again
Bitsa
« Reply #5 on: February 02, 2015, 12:32:58 PM »
Ash
Let me know what they come out like please Ash
« Reply #6 on: February 02, 2015, 12:36:28 PM »
Hi Julie
All the best
Ralph
Sorry Ralph, photo's not good as doing on my bobile. Will try again later. The deposits actually remind me of chalk, or Rennie indegestion tablets that's why I am assuming it is calcium.
« Reply #7 on: February 02, 2015, 12:52:01 PM »
What have you done Julie. May be a new set of carbs is needed ;D Just clean it off
« Reply #8 on: February 02, 2015, 01:18:56 PM »
I haven't broken them and no one had died so it ain't a real disaster. Just not quite what I was expecting.
« Reply #9 on: February 02, 2015, 01:56:10 PM »
Julie
Its coming back to me when I got mine done.It was not what I expected also they did not look as bugger all had been done to them and yes a powder deposit which have to say all came off with high pressure air gun.
Best of luck
Ralph
« Reply #10 on: February 02, 2015, 05:09:11 PM »
Progress made, crisis averted  :). Put loads of carb cleaner in every orifice I could find on the carbs and took up local workshop and they gave them a really good blow out. But, prior to this the slides were totally seized, or the mechanisms that moves the slides up and down were seized so had to kept putting a mixture of WD40 and carb cleaner in and was gently levering the bit where the throttle cables attach and eventually they started freeing off 1 by 1. Managed to accumulate some of the white powdery deposit, definitely a calcium type deposit, can feel a very slight grittiness to it. It melts totally in carb cleaner and WD 40 but not fully in water, it forms a paste. My first experience of Ultrasonic cleaning on carbs, lesson learnt, won't be going that route again anytime soon  ;D ;D ;D
« Reply #11 on: February 02, 2015, 05:47:15 PM »
Not understanding where the grittiness has come from ? You put the carbs in a ultrasonic machine, wash out with hot water, blow out with air line until dry and squirt a little wd40.
« Reply #12 on: February 02, 2015, 05:52:02 PM »
The grittiness was definately in the white powdery deposits. Maybe grit is a too harsher word for it but you could feel something when rubbing it between you fingers, sort of like a paste.
Offline fisjon
« Reply #13 on: February 02, 2015, 06:07:51 PM »
Hi Julie,
I take it you paid for this to be done, if so you should take them back and get them done again. If they moan about it just tell them that you will let everyone know that they do inferior work.
If any of the 'grit' is left inside the air/fuel tubes then you are going to have probs. I had an ultrasonic cleaner and I had nothing like that in any of the work I did. for an example see photo.
Everything I put in came out clean as a whistle with no crud or powder. I suspect they are not using the correct cleaning agent.
john
Offline Clem2112
  • Midlife
« Reply #14 on: February 02, 2015, 06:21:55 PM »
Nothing wrong with ultrasonic cleaning if its done right  :)
I did some research before I took the ultrasonic route.....
The media should not be too aggressive and something like Sea Clean is considered safe for alloy carb bodies.
Using acidic or alkaline fluids or ones containing abrasives are not a good idea.
The carburettors need to be completely stripped first - the liquid needs to be able to get into all the passages and voids and be free to drain out afterwards.
Jets and other loose parts can go in too but I don't know if the tiniest holes allow much liquid through?
It's essential to blow out all these internals with compressed air after cleaning.
After drying in a warm airing cupboard I sprayed the outsides with WD40.
Total cost £40 for a small cleaner and £8 for the fluid.
