Author Topic: Intake differences - which to use?  (Read 5756 times)
Offline JustcallmeMrT
« on: February 15, 2015, 04:50:17 PM »
I've got three engines sitting here by now, and two have intakes with a screw/port in the side, and one doesn't.   Wondering which I should use in the current build.  Which is best?
Re: Intake differences - which to use?
« Reply #1 on: February 15, 2015, 04:55:11 PM »
Those screws/ports are where you attach vacuum gauges to synchronise the carbs, use those!:))
« Reply #2 on: February 15, 2015, 05:16:40 PM »
Confirmed what I thought.  Unfortunately those are in worse shape - time for more prep and paint!
Offline hunterso
« Reply #3 on: February 15, 2015, 05:42:05 PM »
The ports you use will depend on which type of carbs you have.
The PD46 carbs have their own sync ports so you will use the intakes without.
If you have the other carbs (without the sync ports) you will need the intakes with the ports.
Check your carbs - good luck - you seem to be storming on with your project  8)
« Reply #4 on: February 15, 2015, 06:02:14 PM »
Not only that but he rubbers and spacings are different. decide which carbs thaen you have to use the manifolds to suit
« Reply #5 on: February 16, 2015, 08:49:57 PM »
Thanks for the info.  The intakes that came off my carbs have the synch ports, so I'll be using those.  What a learning curve this all is!
Offline Norniron
« Reply #6 on: February 16, 2015, 10:23:09 PM »
Good choice T
1977 400 cafe
1972 500/4
2013 triumph STR675
