Project Board
f2cafe racer
20
21
22
23
29
Topic: f2cafe racer (Read 128993 times)
MarkCR750
Professional half wit and member
Re: f2cafe racer
Reply #300 on:
May 13, 2016, 10:07:44 PM »
I'm liking the velocity stacks, how's the fuelling with them fitted, do they have an internal gauze?
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
yozzer74
Re: f2cafe racer
Reply #301 on:
May 13, 2016, 10:18:03 PM »
Don't no about fuelling yet .but they do have gauze inside them .
MarkCR750
Re: f2cafe racer
Reply #302 on:
May 13, 2016, 10:54:20 PM »
Cheers, I might go for a set of those .
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
yozzer74
Re: f2cafe racer
Reply #303 on:
May 14, 2016, 10:01:19 AM »
I got them from dime city cycles in US
MarkCR750
Re: f2cafe racer
Reply #304 on:
May 14, 2016, 03:36:02 PM »
Cheers, actually I'm just trying something this afternoon , fitting velocity stacks inside my pod filters (home made) just to see what happens (if anything), but I'll no doubt move to just stacks for appearance sake eventually .
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
yozzer74
Re: f2cafe racer
Reply #305 on:
May 17, 2016, 07:30:57 PM »
Started making my wiring harness .with the help of Bryan drawing a diagram for me. [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
yozzer74
Re: f2cafe racer
Reply #306 on:
May 30, 2016, 08:26:42 PM »
Need a little help with my wiring got all lights working starter motor turns engine over but I have no spark wired yellow& blue wires from points to coils then black&white to switch .but there's no spark any ideas what to look for .Cheers
K2-K6
Re: f2cafe racer
Reply #307 on:
May 30, 2016, 08:57:48 PM »
You should have a constant 12v supply to the coils with ignition switched on and the coils earthed through the points only when they are closed.
When you rotate the crank, the wires through the points should lose continuity to earth as the points open. If not, then you'd suspect the insulator washers where the wires and condensers connect to the points as if they are assembled wrongly the wire tracks to earth before it even gets to the contact face to be switched by the points.
yozzer74
Re: f2cafe racer
Reply #308 on:
May 30, 2016, 09:02:42 PM »
I'm getting 12 volts to coils when ignition is on and I haven't touched the points as the bike was running before I stripped it .Will check tomorrow
K2-K6
Re: f2cafe racer
Reply #309 on:
May 30, 2016, 09:14:19 PM »
Easy way to check the points is disconnect the blue\yellow wires and open the points then put a piece of card in the gap, then continuity check down each wire to the points across to earth and you should have no continuity. Pull the card out and continuity should be there with the points closed.
yozzer74
Re: f2cafe racer
Reply #310 on:
May 30, 2016, 09:17:24 PM »
Thanks I will give it a try
yozzer74
Re: f2cafe racer
Reply #311 on:
May 31, 2016, 04:03:55 PM »
I've disconnected the blue and yellow wire from the points put card in between points now how do I test for continuity
K2-K6
Re: f2cafe racer
Reply #312 on:
May 31, 2016, 04:46:13 PM »
Have you got a volt meter that beeps when you connect the two probes together?
I so you put one probe onto one of the wires to the points and the other on onto the points mounting plate and you should have no connection\beep.
The status you are looking for with the card in place is for no electrical connect through the points to earth, if it tracks through then you are looking at a fault somewhere in that system you've checked.
yozzer74
Re: f2cafe racer
Reply #313 on:
May 31, 2016, 04:55:08 PM »
Yeah I have one I will go out and give it a try cheers
yozzer74
Re: f2cafe racer
Reply #314 on:
May 31, 2016, 05:52:11 PM »
Ok so I've done that test I don't get a beep at all with card in or out when I touch the back plate only time I get a beep is when I touch number 2&3 points
20
21
22
23
29
Project Board
f2cafe racer
