Author Topic: Rocker arm shafts - ?  (Read 5885 times)
Offline JustcallmeMrT
« on: February 18, 2015, 08:44:44 PM »
Pulled the rocker arm shafts so I could prep the cover for paint, and noticed that while every other tappet has its own shaft, 1 and 2 inlet shared a common one with a notch in the far end.
Normal or odd?
Re: Rocker arm shafts - ?
« Reply #1 on: February 18, 2015, 09:57:07 PM »
Normal or odd?
CB500 and CB550F1 have there own shaft. The K3 and F2 share a shaft. The long shaft for the K3 and F2 have the notch were 14456-390-000 goes in the notch to stop the shaft turning.
« Reply #2 on: February 18, 2015, 10:25:19 PM »
Normal or odd?
So its actually odd that the others are independent?
« Reply #3 on: February 19, 2015, 08:45:12 AM »
Can't remember how many rocker covers i see in your garage. Maybe you have the two different covers. They changed after number 1133172. I think the only difference was that you could lock the shafts that have the notch.
« Reply #4 on: February 19, 2015, 09:00:26 AM »
Only 2.  I can't manage to pull the shafts out of the other cover to compare, so will just reassemble as it was and go with it!
Any suggestions for a source for seals for the side covers, or is any one as good as the other?
« Reply #5 on: February 19, 2015, 09:03:24 AM »
Seal is a seal, as long as it fits and does the job. No such thing as a original anymore. Should be a couple of buck's.
If the others will not come out then maybe you still have 14456-390-000 still in place.
« Last Edit: February 19, 2015, 09:07:00 AM by Trigger »
« Reply #6 on: February 19, 2015, 01:03:57 PM »
Will have a look.  Thanks again!
