Author Topic: Data plate  (Read 8329 times)
Offline Myford
Data plate
« on: February 19, 2015, 03:49:12 PM »
Hi,
can anyone tell me a part number for the rivets that hold the Data plate on, or where I can get any?
I guess  for obvious reasons they're not listed in the Honda parts book.
Terry
Offline Piki
Re: Data plate
« Reply #1 on: February 19, 2015, 06:15:14 PM »
Data Plate in a 400Four?
Re: Data plate
« Reply #2 on: February 19, 2015, 06:21:32 PM »
I have some Honda ones but, the problem is that they are only 1.5mm x 5mm. If the ID of the hole has rusted a bit they will just fall in the hole and not grip. If you have a 1.2mm drill bit then test the size of the hole first. If the drill bit is lose then just use a pop rivet.
Re: Data plate
« Reply #3 on: February 19, 2015, 07:37:15 PM »
I've got some spare.
« Last Edit: February 20, 2015, 06:11:41 PM by mike the bike »
Re: Data plate
« Reply #4 on: February 20, 2015, 01:14:50 PM »
908410001-000 Dave Silver used to keep them
Offline Myford
Re: Data plate
« Reply #5 on: February 20, 2015, 07:41:24 PM »
Thanks guys for all the advice, much appreciated.
Bryan, are you sure of that number, seems to be a dash missing, but even with a dash seems to be too many digits, it's not recognized.
Terry
Re: Data plate
« Reply #6 on: February 20, 2015, 08:14:16 PM »
There is 1 to many noughts in it Bryan works late
Try 90841-001-000
Bitsa
Re: Data plate
« Reply #7 on: February 20, 2015, 11:32:56 PM »
Late is right mate, started 18:30 Thurday finished 08:30 Friday after 600km and over 9 hours driving!! Yup hit a nought instead of a dash---I blame the Dyslexic keyboard personaly!!!
Re: Data plate
« Reply #8 on: February 21, 2015, 07:45:32 AM »
Terry
Terry, If you Pm me your address i will post you a couple for free.
Offline Myford
Re: Data plate
« Reply #9 on: February 25, 2015, 05:34:45 PM »
Thanks Trigger,
Rivets arrived today. It'll be a few weeks before I get on to it, as I've just found out I've got a heart thing called Atrial fibrillation which at the moment doesn't put be in the mood for anything much. I'm told once the medication is sorted it should stabilize.
Anyway I'll keep you posted (about the rivets :).
Regards
Terry
Offline Myford
Re: Data plate
« Reply #10 on: March 30, 2015, 07:16:28 PM »
Well the rivets went in just fine, nice and tight, just needed a tap in with a small hammer.
Thanks again Trigger.
Terry
Re: Data plate
« Reply #11 on: March 30, 2015, 08:12:16 PM »
Terry
Your welcome. I bet you thought i had sent you two empty Honda bags at first, bloody small things  ;D
