Author Topic: CB750K2  (Read 5994 times)
Nelly
CB750K2
« on: October 09, 2006, 12:54:31 PM »
Hi,
Just bought CB750K2, always wanted one but know nowt about um. Seems pretty good UK bike circa 1972, Clutch is dragging a little, is replacement difficult/expensive? neutral light seems a bit iffy, staying on constantly but getting brighter when true neutral is found  and is there anyway of stopping the front disc from bloody squeaking all the time.
Neil
Re:CB750K2
« Reply #1 on: October 09, 2006, 05:40:27 PM »
First of all - welcome to the forum!
In order:
1. Clutch drag is just adjustment. Get a manual and have a go. You may have to replace the clutch cable if you are unlucky.
2. Neutral light is driven by an eccentric drum switch under the clutch cover. Clean it.
3. Disk squeak. They all do that sir. Actually this is down to cleaning and adjustment too. You won't be able to adjust it properly without cleaning it all up first. Especially the groove inside the brake cylinder (the one that the square-section seal sits in).  Once cleaned up, follow the manual instructions as to how to adjust it.
Post back.
Re:CB750K2
« Reply #2 on: October 09, 2006, 05:41:20 PM »
PS.
Where are you?
There's nothing like a bit of help with your first bike.
Nelly
Re:CB750K2
« Reply #3 on: October 10, 2006, 03:18:39 PM »
Thanks for the info steve, I,ve got a manual on the way so I,ll be getting stuck in soon. Had various covers and bits off last night, the wiring looks quite creative. I,m in Bury north Manchester,
cheers
Neil
Offline JonnyB
    • BatchScan
Re:CB750K2
« Reply #4 on: October 10, 2006, 04:45:48 PM »
I had to do some repairs to my wiring loom.
If you need to replace any connectors, I've used these bullets connectors they are a good match.
http://www.autoelectricsupplies.co.uk/product_list/6
I've used thier cable to
http://www.autoelectricsupplies.co.uk/product/70
Regards and Ride Safe!!
Daily Ride - BMW K1200GT
Summer Fun - Naked K100
Current Project - GS500E
John
https://batchscan.co.uk/
