Author Topic: Difference between exhaust pipes  (Read 4444 times)
Offline Peter_plade
« on: February 24, 2015, 02:11:05 PM »
I bought a couple of used right side exhausts for my 76 550, but noticed that they weren't 100% identical.
If I look in the end of the pipes, the 2 left ones that is original to the bike has a center hole and smaller holes around it, the 2 right side only has the center hole. Why is that? And does make any difference?
Re: Difference between exhaust pipes
« Reply #1 on: February 24, 2015, 03:13:07 PM »
if you look at the top pic,the added holes are not uniform,and appear to have been added by the
previous owner
Offline Peter_plade
« Reply #2 on: February 24, 2015, 03:41:50 PM »
You are right hadn't noticed that, guess I will have to fire up the welder.
Offline matthewmosse
« Reply #3 on: February 24, 2015, 06:49:23 PM »
I had a mate who used to bodge extra holes like that to 'increase power' by bypassing or destroying the backpressure. I would weld it up if I were you. Might make the bike louder but especially if just done to one could just screw up the jetting and carb balance.
