Author Topic: My 76 550  (Read 12179 times)
Re: My 76 550
« Reply #15 on: February 28, 2015, 07:33:49 PM »
Wise man ;) ;)
Bitsa
My 76 550
« Reply #16 on: February 28, 2015, 10:19:22 PM »
No probs - think I'v managed to source a nice set from the US so should be sorted. James.
Offline petersy
Re: My 76 550
« Reply #17 on: March 08, 2015, 04:54:58 PM »
I thought about changing the handlebars for the euro one, but don't were I can find one?
I put Norton straight bars on my last CB350. I like the look and feel of a forward leaning position. Wish I hadn't sold the bike though
Offline LesterPiglet
  • 1977 CB550F2
Re: My 76 550
« Reply #18 on: March 21, 2015, 02:23:04 AM »
I like the straights. Had them on my triple and found them very comfortable.
Offline Peter_plade
Re: My 76 550
« Reply #19 on: March 29, 2015, 04:31:50 PM »
I have now changed the bars for a euro style. Only problem is that the gas cables seems to be to long so it doesn't let go of the gas quite as good as I want it. Any ideas besides changing the cables?
Re: My 76 550
« Reply #20 on: March 29, 2015, 04:40:31 PM »
Unfortunately not Peter - got to have the correct length throttle cables I'm afraid..
Re: My 76 550
« Reply #21 on: March 29, 2015, 07:21:39 PM »
Check that you have enough slack in the "pull/opening" cable, if you don't then you get a conflict between the pull and push cables that can change as you turn the handlebars and also make the thottle heavy. As James says it's ideal to use the correct length cables but check the above first to see if you can gain an improvement.
Offline Peter_plade
Re: My 76 550
« Reply #22 on: March 30, 2015, 10:34:29 AM »
I tried to reroute the cables that helped but I'm still not satisfied, so I ordered a set of correct cables. I think my clutch cable might also have a little problem with the lower bars.
