Author Topic: soft front brake  (Read 9261 times)
Offline Rirons
soft front brake
« on: March 04, 2015, 12:27:09 PM »
I have been trying  to get decent lever for my front brake forever.
When i bought the bike it had a non standard single hose (no pressure switch for brake light)
Whilst restoring i changed to the 3 hose system, manifold with a brake switch, never got a decent lever.
I have rebuilt the frame etc this winter so tried again no better, new piston and seal fitted to the caliper, new plunger etc in the master cylinder.
Reverted back to the single hose and no problem which tells me the caliper and master cylinder is ok.
Anyone had similar issue any advice would be greatly appreciated.
Offline tom400f
Re: soft front brake
« Reply #1 on: March 04, 2015, 12:39:01 PM »
Hi and welcome
I assume you mean two hoses - master cyl to union, union to caliper (via fixed pipe on the caliper if you have the standard setup).
What condition are your hoses in? I have new braided ones from Earls with no problems. I also bleed the system using a syringe on to the bleed nipple and forcing any air up and out via the reservoir.
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
« Reply #2 on: March 04, 2015, 01:06:34 PM »
it sounds as if one or more of the hoses need replacing.  If you grip your fingers around the hose and operate the brake, you can feel the hose expand with the pressure.  braided hoses solve the problem.  I sleeved mine with black shrink wrap to make them look a bit more authentic.
Offline Rirons
« Reply #3 on: March 04, 2015, 03:56:45 PM »
Thanks for the replies, the hoses are new and yes two hoses and one fixed pipe.
I will try the pinching the hose etc, ordered a syringe of fleebay to try the reverse bleeding technique.
Ill let you know.
cheers
« Reply #4 on: March 04, 2015, 07:21:56 PM »
Sorry guys just can not get my head around your brake problems.On all rebuilds new pipes new master cylinder kit new pads new fluid and all done in 5 mins.
WTH are you doing wrong? :D
Bitsa
Even with a DS repro master cylinder done in 5 mins
« Reply #5 on: March 04, 2015, 08:26:21 PM »
how are the brake pads ??
 if they are not bedded in,they may cause a spongy lever as the pad hits the disc,
« Reply #6 on: March 04, 2015, 08:29:21 PM »
I thought a syringe was for injecting drugs etc
You old boys tell me I am right or do you use them?
Bitsa
« Reply #7 on: March 04, 2015, 08:44:17 PM »
when I need to replace a brake pipe ,before I take it all appart,I pump the caliper as full as I can,without the pads in !!,
then swop the parts,re assemble,and then push the caliper piston in,this fills the pipes and up to the mastercylinder,
 check the fluid level,top up,then bleed normally,to make sure there are no air bubbles,
works well for me
« Reply #8 on: March 04, 2015, 09:13:25 PM »
Bitsa
You told me it took you 7 minutes  ;D ;D ;D
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #9 on: March 04, 2015, 09:43:33 PM »
Hi Rirons,
Been there... done this... two old Hondas, one with a brake lever that pulled 1/2" to full on; and the other that pulled all the way to the grip. New pads, hoses, gallons of bloody fluid... in my case a new master seal kit (DSS) was the answer. Don't particularly understand the physics..  just eventually got there through elimination.
Frustrating & expensive... but now all good. Happy hunting...
Simon
« Reply #10 on: March 04, 2015, 09:47:22 PM »
It is a brake system so, treat it as a system  ;)
« Reply #11 on: March 05, 2015, 09:37:53 AM »
Trig
No the other 2 mins was finishing my drink mate? ;) ;)
Bitsa
« Reply #12 on: March 05, 2015, 11:03:35 AM »
Trig
Bitsa
See i did tell you that the master would be OK  ;)
« Reply #13 on: March 05, 2015, 07:10:31 PM »
Trig
Yep you did and encore droit
Bitsa
Offline Rirons
« Reply #14 on: March 09, 2015, 12:51:22 PM »
The reverse bleeding technique worked cheers tom400f
To answer the other questions, i have not idea what if anything i was doing wrong, but it didn't work and it does now. 8)
