Author Topic: 400-4 Tappet Adjustment using thread pitch?  (Read 11957 times)
Offline DayvW
Re: 400-4 Tappet Adjustment using thread pitch?
« Reply #15 on: March 09, 2015, 12:31:15 AM »
Ah... and its a pain, but the bullet connectors are 3.5mm. Bloody hard to source: if you find them in the UK can you post their address here... I've always had to use the 'States...
Simon
Here you go Simon.  Postage steep - if you look on eBay (the second link) you can get a stack and pay no postage - but I didnt need that many!
https://secureshop.co.uk/epages/950000457.sf/sec46a6282db2/?ObjectPath=/Shops/950000457/Products/%22TB-3.5mm%20Bullets10%22
http://www.ebay.co.uk/itm/50-JAPANESE-3-5mm-BRASS-BULLET-TERMINAL-CONNECTOR-HONDA-SUZUKI-KAWASAKI-YAMAHA-/291381133915
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #16 on: March 09, 2015, 12:42:06 PM »
By crikey Dave,
That's expensive. But honestly, we're stuck between a rock & a hard place. I too figured I could 'crimp' the 3.9mm bullets to fit... but you end up with a naff connection that you just KNOW is gonna fail at the worst time....
I ended up buying a load of 3.5mm's ..  in the realisation that I'm likely to restore another old Honda or two at some point; but in any case appreciate a stock-in-hand.
Nonetheless appreciate the UK address.... & now stored safely away.
Thanks,
Simon
Offline DayvW
« Reply #17 on: March 09, 2015, 01:52:33 PM »
Indeed ... but came to same conclusion .. better with 3.5s.  I'll see what the quaility is like on 10 and then may order a shed load as I can imagine needing a few over the years!
