Author Topic: Front fender and rear shocks  (Read 14273 times)
Offline El__burro
Re: Front fender and rear shocks
« Reply #15 on: June 04, 2015, 06:10:14 PM »
Honda use alot of M10 fine threads, rear shock lower bolts with standard unit are M10 fine and top fixing nuts are usually M10
i need to fit the top bolts for the rear shocks, but the M10 fine are way too small.
either the seller has sent me the wrong item (the bolt external diameter is 12.89mm) or Martin meant M12.
Which one is it?
thanks
el__burro
Offline El__burro
« Reply #16 on: June 09, 2015, 10:44:36 AM »
wrong size bolt sent by the seller. it looks like it was a m8 bolt.
el__burro
Offline El__burro
« Reply #17 on: June 14, 2015, 03:28:57 PM »
what are the differences between cb750 and cb500/550 speedo drive plate.
i need to purchase the second type for a dual disk upgrade but probably i already have one somewhere.
can anyone help with some pictures.
thanks
el__burro
« Reply #18 on: June 15, 2015, 09:21:42 AM »
IT IS A MYTH THAT THE %)) ONE WORKS-----IT DOESN'T
Offline El__burro
« Reply #19 on: June 15, 2015, 09:34:48 AM »
500?
Doesn't work,  what about the 550, %%)
They look identical.
El__burro
« Reply #20 on: June 15, 2015, 10:11:02 AM »
The 750, 550 and 500 are all exactly the same and do not work with twin discs
Offline El__burro
« Reply #21 on: June 15, 2015, 10:19:36 AM »
are we talking about part number 9 in the picture below?
thanks
el__burro
« Reply #22 on: June 15, 2015, 04:58:40 PM »
yes
Offline Yamahawk
« Reply #23 on: November 09, 2017, 11:12:59 AM »
Hi Mark,
   This link to the dual disk conversion isn't valid anymore, is there another way to get the info for the conversion? Thanks!
Charlie
« Reply #24 on: November 09, 2017, 04:29:33 PM »
These instructions are for a Honda CB 500 or 550 four, they will work for 750 K3 onwards if you get 750 parts where 500/550 are mentioned and earlier ones if fitted with the later fork slider assemblies
Hi easiest way is to collect the following bits:
(1) Goldwing (GL 1000 or 1100) or other Honda twin disc master cylinder complete
(2) 500/550 disc SH
(3) 500/550 caliper with mounting brkt and lower hose c/w banjo bolt and washers
(4) Speedo drive 44641-300-000 (now obsolete but Western hills Honda Cincinnati did have a couple in stock--DO NOT accept the modified number it wont work, there is a photo of the required plate on page two from which you should see how to modify the drive you have)
(5) Two new seals for caliper, part number 45108-300-003, and preferably two new sets disc pads
(6) Six 8 x 110 HT bolts with nylock nuts.
Strip out, clean (especially the seal grooves) and rebuild both calipers with new seals, remove front brake light switch from block bolted to bottom yoke (lower triple tree?) and connect the second lower hose to the hole uncovered (same thread on banjo bolt), Replace master cylinder with twin disc type (if you got a "late model" there will be a brake light switch operated by lever blade. If so, connect this to wires from removed switch--if not rely on rear brake light switch).
On front wheel remove front wheel spindle and Speedo drive gearbox, remove and discard six disc rotor holding bolts, chrome cover and Speedo drive plate.
Fit New? Disc with longer bolts and nyloc nuts. Fit replacement Speedo drive plate.
(This may necessitate cutting part of the aluminium disc center out to form two rectangular slots). Refit the Speedo drive gearbox and wheel spindle.
Bolt wheel into forks and bleed brakes. You now have twin discs using all standard parts if it still wont slow down enough you are driving too fast.
If you want the picture that goes with this you will have to PM me with your email address but you won't get an answer till after 19th as i am away from now
« Last Edit: November 09, 2017, 04:36:06 PM by Bryanj »
Offline Yamahawk
« Reply #25 on: November 12, 2017, 01:13:02 PM »
Thanks, Bryan!
Charlie
