Author Topic: Surplus dust seal on front brake caliper?  (Read 5785 times)
Offline Stuartbellwood
« on: March 30, 2015, 06:32:11 PM »
Hi all
I recently bought a replacement front brake calliper for my 550
It came with the piston and seals all separate, along with the seal is apparently a dust seal, basically looks like a thinner version of the seal itself.
Can any one tell me where this goes please? It won't fit into the groove with the seal and if I put it on the exposed part of the piston then it won't be any use at all once I've applied the brake once
Any help greatly appreciated!
Thanks stuart
Offline Tiny Tim
Re: Surplus dust seal on front brake caliper?
« Reply #1 on: March 30, 2015, 06:47:42 PM »
This may help [ Guests cannot view attachments ]
Offline Phil k
« Reply #2 on: March 30, 2015, 06:55:21 PM »
Stuart
There should be two grooves in the housing. The deeper (from the face) carries the seal, the higher groove carries the wiper or dust seal.
Good luck
Honda CB750 K5
2004 BMW R1100s
Honda CRF250X
Honda CRF230F
« Reply #3 on: March 30, 2015, 07:09:22 PM »
Can't say I've ever seen a second groove on a 350/400/500/550 or 750 front caliper, or the dust seal. The diagram above doesn't show one either. It's possible that any aftermarket seal "kit" may also fit othet makes which do use them, but are surplus to your requirements. :))
Offline Green1
« Reply #4 on: March 30, 2015, 07:40:07 PM »
There's only one seal in both my 750 callipers.
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #5 on: March 30, 2015, 08:05:56 PM »
Only one seal on 350,400,500,550 and 750 ;)
« Reply #6 on: March 31, 2015, 04:42:08 PM »
Some other Hondas use a twin sealed piston that is the same size so perhaps it is a "generic" piston kit
