Author Topic: Carbs  (Read 8241 times)
Offline Dundrod
Carbs
« on: April 08, 2015, 02:24:17 PM »
Need help with my carbs set up as it seems to be all over the place I am running pod filters with a Mizuno / Yoshi rep exhaust DS electronic ignition standard jets float heights and needle height so far air screws out 2.5 turns I can get the carbs balanced nicely then give it a rev and the revs take off alternatively she will struggle to start fart and backfire was thinking of jetting up anybody know anywhere in the uk that does jets I replaced all the carb jets seals etc with new kit from Cruzin Image seals and O rings replaced from Holland and carbs were ultra sonic cleaned thanks in advance for any advice its doing my head in  :o
Re: Carbs
« Reply #1 on: April 08, 2015, 02:47:39 PM »
Sirius in Canada(http://www.siriusconinc.com/pro-detail.php?pid=&product_id=176) do a jet "Kit" with several different sizes of mains. What size are yours as 500 ones might be a bit bigger and I have a few of those somewhere
Offline Dundrod
Re: Carbs
« Reply #2 on: April 08, 2015, 03:07:12 PM »
Thanks for the reply Bryan the stock size is 75 for the main jet if you have any that may help I will buy them from you thanks
Offline Norniron
Re: Carbs
« Reply #3 on: April 08, 2015, 10:06:35 PM »
Im running with pods,yoshi and dyna ignition on my 400.
I increased the main jets to 85 and as yet have no problems.
500 jets are 100 and may cause her to run too rich
« Last Edit: April 08, 2015, 10:08:13 PM by Norniron »
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline Dundrod
Re: Carbs
« Reply #4 on: April 08, 2015, 10:25:14 PM »
Thanks Norn Ive a set of jewellers drill bits and the jets I replaced will try gong up in .05 mm increments just to see, where did you get your 85 jets?
Offline Norniron
Re: Carbs
« Reply #5 on: April 08, 2015, 11:05:22 PM »
I cant remember if it was "sirius" or "jets r us"
U are nearly there.running pods can be tricky.all the advice telling you not to remove the airbox is right.
U also may need to increase the idling speed
1977 400 cafe
1972 500/4
2013 triumph STR675
Re: Carbs
« Reply #6 on: April 09, 2015, 07:42:37 AM »
I wont have anything that small mate but I am sure sirius will alter the jet sizes in the "Kit" or I know they sell individualy or sets of 4
Offline Dundrod
Re: Carbs
« Reply #7 on: April 09, 2015, 09:19:04 PM »
Again thanks for the replies Sirius are out of the kits at the moment nrp carbs have 85s so might give them a go it will keep me busy get this right and the bikes finished for now
Offline Norniron
Re: Carbs
« Reply #8 on: April 09, 2015, 09:28:00 PM »
I use redex in every third fill of the tank.
It stops the carbs gumming up when not in use.
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline Norniron
Re: Carbs
« Reply #9 on: April 09, 2015, 09:30:55 PM »
I have spare size 75 jets if u want to rebore them with your bits.
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline Dundrod
Re: Carbs
« Reply #10 on: April 10, 2015, 01:26:27 PM »
Thanks for the offer Norn but I have 8 of the 75s to play about with did you do anything with your idle jet ?
Offline Norniron
Re: Carbs
« Reply #11 on: April 10, 2015, 08:23:11 PM »
No i didnt do anything with the idle jet but i suspect i ought to.
I just turned up the idle speed to about 1600rpm.
1977 400 cafe
1972 500/4
2013 triumph STR675
Re: Carbs
« Reply #12 on: April 11, 2015, 09:54:20 AM »
Norniron, you will never get your beast to tick over because of the exhaust you are running  ;D
Are you back on a STD air box ?
Offline Norniron
Re: Carbs
« Reply #13 on: April 11, 2015, 12:47:29 PM »
No trigger not yet
1977 400 cafe
1972 500/4
2013 triumph STR675
