Author Topic: Neutral light won't go out.  (Read 5846 times)
Offline dieffe
    • My website
« on: April 09, 2015, 04:18:08 PM »
This is odd, when I put the bike in gear the neutral light goes dimmer but doesn't go out altogether. I disconnected the wire from the sender and it went out until I earthed it and then it came on ok.
Any ideas?
Re: Neutral light won't go out.
« Reply #1 on: April 09, 2015, 04:26:29 PM »
It's a dodgy neutral switch.   You could try removing it and giving it a good clean up, if that doesn't work, replace it
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: April 09, 2015, 05:46:14 PM »
Watch when you put the casing back on. My switch earthed against it on the odd occasion. Took me ages finding the problem.
« Reply #3 on: April 09, 2015, 05:53:10 PM »
Not an issue on the 750 as the switch is under the engine:))
Offline Waggles
« Reply #4 on: April 10, 2015, 09:32:44 AM »
Has the switch been removed recently? if so, check the fitting of it and the o ring.
this has come up b4:
http://www.sohc.co.uk/index.php?topic=2292.0
Offline dieffe
    • My website
« Reply #5 on: April 10, 2015, 04:55:42 PM »
Just read through the other thread and it has given me a few things to try, thank you.
Note to self, the search box is my friend.  ::)
« Reply #6 on: April 11, 2015, 10:15:50 AM »
My 750F1 neutral light stuck on not long after I bought the bike, I changed the switch but it did not cure the fault so I stuck some tape over the light, when I overhauled the bike I found that the switch wire had rubbed and was shorting on the bottom of the crankcase, taped it up and it's been OK ever since.
