CB350/400
Cam chain
Topic: Cam chain (Read 7171 times)
paul G
Cam chain
April 18, 2015, 02:17:06 PM »
Hi all,
Thinking of doing the cam chain, looks like the guides are worn but the chain doesn't look bad, not worth splitting the cases for anyway.
Has anyone got any experience/comments on fitting a new chain but splitting and riveting !!
Regards,
Re: Cam chain
April 18, 2015, 02:48:31 PM »
Did lots when in the trade but only with the proper riveting tool which ain't cheap
paul G
Re: Cam chain
April 18, 2015, 04:11:32 PM »
Brian,
Quite a few for sale on the net.
What is special about the genuine article, anything.
Regards,
Tiny Tim
SOHC Member
Re: Cam chain
April 18, 2015, 04:51:15 PM »
Hi,
When I replaced the cam chain on my 550 I soon discovered that buying a cheap chain splitter(£40) is a bad idea. The tool broke and the cam chain remained intact
I ended up borrowing a decent one from a local bike shop.
Re: Cam chain
April 18, 2015, 11:53:07 PM »
I dont have a camchain splitter and would/t trust a cheap one, best i ever used was a Yamaha one
kettle738
SOHC Member
Re: Cam chain
April 19, 2015, 08:01:50 AM »
Every CB450 and 500T uses a soft link cam chain from new......the soft links are fine, it's just the question of fitting them properly, get that right and you will have no problems........ and save yourself an awful lot of time and money.
Mick..........kettle738
Re: Cam chain
April 19, 2015, 05:26:55 PM »
That's the whole point Mick, its the tool to fit them properly that costs
mike the bike
CB400F, Royal Enfield Interceptor.
Re: Cam chain
April 19, 2015, 10:04:46 PM »
I've used the 500T soft link and it works fine. Some tips though..
Before you grind the rivet pin off, stuff some oily rags around to catch the swarf.
Get a split link, same size, to join the new chain to the old. turn the engine over using a 22mm spanner on the crank (points side) until the new chain is fed through.
Keep the rags in place, you don't want to drop any soft link bits down the tunnel
Use a large hammer on the back of the rivet as something to hammer against.
Check the timing, just in case.
Hope this helps
Re: Cam chain
April 20, 2015, 07:46:48 AM »
There was a Honda tool in the 450/500 twin workshop tool kit specificaly for splitting and joining the chain as the twins had to be split to get the head off, but it was a pain to use the Yamaha one did the same job easier.
Using two hammers it is too easy to leave the rivet link too loose or too tight, either of which causes problems
CB350/400
Cam chain
