Author Topic: CB350F Restoration by royhall (NOW FINISHED)  (Read 89878 times)
Re: CB350F Restoration by royhall
« Reply #165 on: December 22, 2015, 01:20:05 PM »
Five more pictures.
Thanks for following the thread. Can hardly believe its been viewed nearly 6000 times.
Will follow up with MOT and DVLA registration feedback after Christmas.
And a special 'thank you' to all the people that helped this build along the way, be it services, parts, or simply help and advice.
Thanks for viewing, and I hope you all have a very Happy Christmas and Santa brings you all the SOHC parts your hearts desire.
« Last Edit: December 22, 2015, 01:22:35 PM by royhall »
« Reply #166 on: December 22, 2015, 01:36:14 PM »
Absolutely gorgeous
« Reply #167 on: December 22, 2015, 01:58:36 PM »
Well done Roy, a stunning piece of work there. You should be very proud.
« Last Edit: December 22, 2015, 06:51:19 PM by Jamesh_sussex »
Offline andut
  • CB400F, CB400F Cafe & NC30
« Reply #168 on: December 22, 2015, 04:19:16 PM »
Superb Roy ! You should be very proud !
« Reply #169 on: December 22, 2015, 05:48:10 PM »
Pick the best shot(s) and put it (them) in the Gallery Roy.
Steve
Offline UK Pete
« Reply #170 on: December 22, 2015, 10:35:49 PM »
Top job Roy , what a gem of a bike
pete
Offline yozzer74
« Reply #171 on: December 23, 2015, 12:38:36 AM »
WOW great build  ;)
Re: CB350F Restoration by royhall (NOW FINISHED)
« Reply #172 on: December 24, 2015, 05:54:23 PM »
Looking great. Good work.  :D
Offline Noelia
« Reply #173 on: December 24, 2015, 06:24:05 PM »
Looks awesome
Noelia
« Reply #174 on: December 24, 2015, 06:50:37 PM »
That looks really lovely Roy, it's a credit to you and keeps another old girl on the road
Offline Tiny Tim
« Reply #175 on: December 25, 2015, 01:58:34 PM »
Bike looks fantastic Roy, well done.
Offline mickwinf
« Reply #176 on: December 27, 2015, 10:57:14 AM »
very pretty bikes the 350!
« Reply #177 on: February 17, 2016, 07:33:36 AM »
Hi all.
The saga isn't quite finished after all. The bike was all setup and ready for testing on the road prior to taking for its MOT, even had the bike in the drive and my helmet on the wall. I was warming it up when I noticed smoke from cylinder 4 exhaust. On checking pot 4 was hardly running, so it was a 3 1/3 cylinder Honda.
Back in the garage I checked for a good spark and No.4 was very weak compared to the others. Unfortunately I couldn't swap 1 & 4 as the leads wouldn't reach, so I stripped off the coil to have a look. On inspection the HT lead to 4 was very loose in the coil body. The smoking gun!
Decided, after a false start with DSS pattern coils, that I would go with a full Boyer Bransden electronic kit with the micro coils. This would also replace the mechanical advancer that was previously freed off after being rusted solid.
When the kit arrived it was clear that the fitting of it was a bit DIY, with no way of mounting the coils and instructions to cable tie the control box to the frame. Sorry that's not going to happen on this bike, a slightly more elegant solution will be required.
This is the story in pictures:
These are the micro coils. They look to me to be the same as fitted to a standard Hinckley Triumph?
My new DSS supplied plug caps are perfect for the job.
As I say a bit DIY, you even have to solder your own HT lead fitting on.
I reversed the original coil mounting brackets and drilled out the threads. If I want to go back to standard I can use a longer bolt with a nut. I made up some aluminium pieces and bolted them in. I then mounted the coils to one side, and the control box to the other.
Had to make loads of patch leads as the  bullet connectors were not really Honda size and all were loose. Got there in the end though.
The result was a really fat bright spark on all four cylinders. Strobed the timing at 4500rpm as per instructions, which is a bit unnerving, but all went well.
Guess what, still a 3 1/3 cylinder Honda. The real culprit was a blocked idle jet in carb 4, the whole exercise was just chasing a red herring ;D . Goes to show, even when you are sure the problem has been found it's still worth double checking everything. "O well" at least the bikes now done to the best spec possible, and the dodgy HT lead has gone. I'm sure that would have come back to bite me at some point in the future.
Hopefully now I can road test it and get it MOT'd and registered ready for spring.
Cheers all.
« Last Edit: February 17, 2016, 07:42:22 AM by royhall »
« Reply #178 on: February 17, 2016, 08:24:20 AM »
Glad you got to the root of the problem in the end Roy, you must be well chuffed with the end product. Not so impressed with the way you had to make patch leads though, every additional joint in the wiring is a potential problem for the future ( loose connections/corrosion causing resistance etc.)
Sent from my X5 using Tapatalk
« Reply #179 on: February 17, 2016, 10:04:29 AM »
Just a couple of patch leads really (lazy writing) the rest I cut off and replaced. Crimped and soldered obviously.
« Last Edit: February 17, 2016, 02:54:13 PM by royhall »
