Author Topic: Removing ignition switch  (Read 3911 times)
Offline MarkCR750
« on: May 06, 2015, 06:00:10 PM »
I have asked this before but can't find the old post with the answer, I want to take the ignition switch off my CR replica but will be using lights and indicators (detachable) when on the road, I have a battery isolator switch so I don't really need an ignition switch, I think the advice I was given before was "connect the red and black wire together and connect the brown wires to each other", please could someone confirm if this is correct?, cheers mark.
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Re: Removing ignition switch
« Reply #1 on: May 07, 2015, 07:30:24 AM »
black to red gets you ignition and should get you lights, i will have to check on browns as i think they are for the parking light circuit
« Reply #2 on: May 07, 2015, 09:52:12 AM »
OK in normal running Red to black and brown to brown/white
to get park red to brown
hope that helps
Offline MarkCR750
« Reply #3 on: May 07, 2015, 05:13:04 PM »
Thanks Bryan.
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
