Author Topic: 350/400 engine seals.  (Read 6334 times)
« on: May 08, 2015, 05:36:31 PM »
Could any of you 350/400 gurus confirm that the engine seals for the 350 are the same as the 400. DSS sell a full set of seals for the 400 at a reasonable price, but the 350 seals are all sold separately at much higher cost. Am I safe to just order the 400 set. What a great forum, where else could you ask a question like that and even hope to get a correct answer. Brilliant.
Offline ttr400
    • CB400F special machined parts
Re: 350/400 engine seals.
« Reply #1 on: May 09, 2015, 06:22:54 AM »
Yes they are the same, except for the clutch shafts.
Note: Output shaft seal, check the very small oil feed hole is clear. this is the feed from the secondary pump to supply oil to the gearbox/bearing. I normally use the OEM seal.
Kevin
If you are addicted to the little CB400F then you might want to check out my website.
www.ttr400.com
« Reply #2 on: May 09, 2015, 03:56:54 PM »
I heard that the pattern seals are not good for the sprocket, same reason ttr gave---think I read it on the US site
Offline Tiny Tim
« Reply #3 on: May 09, 2015, 03:59:22 PM »
That is very useful to know.
Still not sure if I will need them just yet.
Offline Lynx
  • Repair & Despair Under One Roof
« Reply #4 on: May 13, 2015, 10:35:39 AM »
Oh God. Now I'm worried because I used the complete DSS seal kit on my 400  ::).
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline ttr400
« Reply #5 on: May 14, 2015, 07:54:53 AM »
I am sure you will be fine, i have used them before but was just saying to be aware etc.
Kevin
www.ttr400.com
