Author Topic: Tacho drive leaking oil  (Read 10366 times)
Offline dieffe
    • My website
« on: May 10, 2015, 06:35:15 PM »
Hi, I know it's not a new problem for you lot but it is driving me nuts. The oil is leaking from the tacho drive on the cam cover, which is not uncommon I gather.
How can this be fixed, I have been told to replace the oil seal but I am having the devil's own job getting the old one out, any hints?
Someone also told me that as they are quite a loose fit and a new seal might not do the job.
Is there a sure fire fix for this?
Ta.
Offline Green1
Re: Tacho drive leaking oil
« Reply #1 on: May 10, 2015, 07:05:47 PM »
A small pick will get it out.
A new seal solved my leak
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline Green1
« Reply #2 on: May 10, 2015, 07:15:29 PM »
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #3 on: May 10, 2015, 08:02:29 PM »
This is how I got mine out after some advice from them that know better, I was a bit nervous about it but it worked a treat. http://forums.sohc4.net/index.php/topic,26190.msg268316.html#msg268316
« Last Edit: May 11, 2015, 08:25:50 AM by Spitfire »
Offline dieffe
    • My website
« Reply #4 on: May 11, 2015, 10:20:30 PM »
Thanks Dennis, the wood screw idea worked brilliantly, put a new seal in and bingo, no leak.
Trouble now is I took it for the MOT, about a 10 mile round trip and there is oil coming out from somewhere near the bottom of the barrels, lots of oil. I thought maybe base gasket but the bottom four or five barrel fins are covered in oil at the front only and I can't think how the oil could travel up from the base gasket.
I read somewhere that the four round oil seals under the cam carriers should have sealant on them but I just put them in dry. If they let oil through where would it come out?
I am going to have to take the engine back out to sort this but it would be nice to have a head start so I can figure out what has gone pear-shaped.
"Do it right first time" comes the cry.  :-[
Oh, it passed the MOT though. :)
« Reply #5 on: May 12, 2015, 06:54:01 AM »
I had a mysterious oil leak on my 400four, couldn't work out where it was coming from.  I used compressed air to pressurise the crankcase via the breather tube at the top of the engine.  Under pressure, the oil squirted out of the gearchange oil seal, which was new from DSS.  Replacing it solved the problem.
I think this would only work for low pressure leaks but it's worth trying.
« Reply #6 on: May 12, 2015, 07:00:58 AM »
Is the oil by any chance coming out around the spark plug cavity's. If it is, could be the rubber penny washers leaking. They are under the cam carriers so engine out for that. Hope its not.
Offline dieffe
    • My website
« Reply #7 on: May 12, 2015, 05:10:18 PM »
I am suspecting the penny washer seals so the motor is coming out again to check it out. Can these be obtained separately as they weren't in the last gasket set I had.
« Reply #8 on: May 12, 2015, 05:13:31 PM »
91318-300-013 quantity 6
Offline dieffe
    • My website
« Reply #9 on: May 12, 2015, 11:12:15 PM »
Thank you, I will see if DS has them, unless you know of somewhere else.
Online martin_uk
« Reply #10 on: May 13, 2015, 10:18:51 AM »
Always worth checking tappet access cover O rings, as often fully compressed/hardened and hot oil can sneak down in all directions >:(
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
« Reply #11 on: May 13, 2015, 11:31:25 AM »
Glad to help
Offline dieffe
    • My website
« Reply #12 on: May 14, 2015, 11:23:23 PM »
Whizzed the cam carriers off today and sure enough one of the penny washer type seals was leaking, there is oil all over #3 spark plug area and is was running down and out from between the lower fins of the barrels.
Major lesson learned, always renew seals on a 44 year old bike!!!!!
I seem to remember that these came with the gaskets sets when I had my K6 in the 70s but obviously there is more money to be made by selling them separately now, or am I being cynical.  ::)
I have ordered some new ones from DS, should I coat them with some ThreeBond (other sealants are available) when I fit them?
As usual, any info gratefully accepted.
« Reply #13 on: May 15, 2015, 06:40:14 AM »
Yes, but not so much it squeezes into the oil ways!
« Reply #14 on: May 15, 2015, 08:36:51 AM »
Its better to put the Threebond into the seat that the washer sits in, then bed the seal into it. That way it seals well and can only squeeze harmlessly out into the spark plug cavity. What a faff to change a few tiny rubber washers though. Big Honda mistake not designing the cam cover to come off in the frame. Would have taken you 1-2 hours to do. Not good.
