Author Topic: CB750K7 - no power from horn or pass button  (Read 5790 times)
Offline ginger_jim
  • Anyone for a Guinness?
« on: May 11, 2015, 09:35:34 PM »
Hi all - any advice when stripping down the LH switch gear?  Any horrors to look out for?
Re: CB750K7 - no power from horn or pass button
« Reply #1 on: May 11, 2015, 09:58:28 PM »
All the little bits are important  ;)
Offline MarkCR750
« Reply #2 on: May 11, 2015, 10:05:41 PM »
I had to strip mine down recently, loads of corrosion on the contact surfaces and the return spring was broken, it's all straightforward to fix though, once you have separated the two halves of the casing and taken the plastic horn button off (held by a small screw on the underside of the button),  you can lift the switch out,  it has a thin (tuffnel?) cover, gently pry it off then you can take out the moving part of the horn switch and clean up the contact faces, I replaced the broken spring with one from a ballpoint pen, then you can glue the switch cover back on with araldite or similar, then reassemble the cases and job done, nothing in there to worry about.
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
« Reply #3 on: May 11, 2015, 10:33:10 PM »
I had to have mine apart recently on my 400/4 and I understand it is the same as the 750. Be careful of the wires (3 in my case)going on to the switch where the springs are . They are soldered on and are a bu**ger to re solder if they come apart or snap off, as my horn wire did  ::) ::) ::) ::)
Have fun  ;D ;D ;D
« Reply #4 on: May 12, 2015, 06:59:02 AM »
Use grease to hold the ball bearings and springs in place when reassembling
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #5 on: May 12, 2015, 08:10:27 AM »
Here ya go Jim... maybe not a K7 but invaluable nonetheless I hope.
Simon
http://forums.sohc4.net/index.php?topic=80532.0
Offline ginger_jim
« Reply #6 on: May 12, 2015, 10:58:12 AM »
wow...thats some post.  I wonder if he did the same write up for the left hand switch gear?
« Reply #7 on: May 12, 2015, 11:15:33 AM »
I have asked him.
Steve
PS: The photos in that post are awesome - it's very difficult to take good detailed shots of small parts like that.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #8 on: May 12, 2015, 02:35:22 PM »
Indeedy... a stunning post for all the right reasons...
Point is Jim, you've now a 'flavour' of how it all is... the LH switch gear will be, as they say in Asia where I work, "same same, but different"
Kinda sums it up nicely.
Simon.
Offline Tiny Tim
« Reply #9 on: May 12, 2015, 06:15:39 PM »
What an excellent post.
Will be very useful when I get to my 350's very tired looking RH/switch gear.
Bought another one to make one good one.
Offline ginger_jim
« Reply #10 on: May 13, 2015, 01:42:21 PM »
Update - numb nuts didn't have the black power in wire connected.  Horn and Pass button functioning perfectly now :)
As in the technology industry, 90% of problems are user error!
« Reply #11 on: May 13, 2015, 01:43:26 PM »
As an IT "professional", all I can say is...
"only 90%?"
