Author Topic: Seat progress  (Read 4097 times)
Offline JustcallmeMrT
Seat progress
« on: May 16, 2015, 02:28:25 PM »
Finally got around to drilling the seat pan I made and covering it in foam.  Decided to go with closed cell high density foam (3cm) for the base, topped with neoprene (1.5cm).  Now to sew a pleated cover and rivet that down!
A piece of advice needed - for the shaping I just used a bit or re-positionable temporary adhesive.  What would you recommend to permanently adhere the foam to the pan?
Offline matthewmosse
Re: Seat progress
« Reply #1 on: May 16, 2015, 03:50:40 PM »
Bmw use a series of alloy strips underneath, about 1mm wide running around the perimeter to sandwich the seat cover material between the seat pan and it, secured by rivetts. Probably the easiest / most durable and easy to re cover seat desighns I have seen, works well in conjunction with inpact adhesive.
