Author Topic: spring left over - carb rebuild  (Read 10348 times)
Offline dellenty1234
« on: May 18, 2015, 07:51:53 PM »
Hello all,
77' 550k carbs, I have just semi rebuilt them and I have a spring with no home! Anybody have a guide or know where this spring may go?
Take it apart anyway he says.....
Re: spring left over - carb rebuild
« Reply #1 on: May 18, 2015, 07:54:52 PM »
Hello all,
a few springs in those carbs, maybe a air screw spring.Need a picture of the spring with a penny in the picture  ;)
« Reply #3 on: May 18, 2015, 08:08:10 PM »
Sorry I thought the picture had uploaded from my phone :s and that's a great help, looks like the spring on section 9! Just need to double check against the carbs.
« Reply #4 on: May 19, 2015, 06:39:45 PM »
Ok, that link didn't help that much, i still cant find it a home.
The spring is that weak i cant imagine it doing a great deal, any how, here is a picture:
The next thing i need help with is actually assembling the "center" of the carbs together (the ends of  the butterfly shafts) Can anybody provide a photo of theirs or some good instructions? feel free to take my photo and show me your 'paint' skills :)
Again, thanks for the help.
James
Offline matthewmosse
« Reply #5 on: May 19, 2015, 06:59:34 PM »
Hopfully photo attatched, spring is it appears off choke as stated
« Reply #6 on: May 19, 2015, 07:02:27 PM »
Another of underside
« Reply #7 on: May 19, 2015, 07:26:34 PM »
Maybe the pictures are unclear, i have just taken a more detailed picture of how its currently situated.
James
« Reply #8 on: May 19, 2015, 07:33:33 PM »
Ken, i believe they are assembled the same as the photos Matt has supplied (thanks Matt)
And as for the spring, i'm not sure if i'm being totally blind but i can't see it for the life of me, I see the main spring situated on the left hand side of the throttle mechanism, but not the spring i have, the ID of the spring is about 17mm i would say.
Offline hunterso
« Reply #9 on: May 20, 2015, 01:16:46 AM »
Here's a couple of pics of my spare carbs - you can see the spring quite clearly
There is a good rebuild guide here - http://www.sohc4.net/cb550-faq/indexphp/pd46a-carb-rebuild-guide-by-brian-barnes
Hope that helps
D
« Reply #10 on: May 20, 2015, 07:53:47 AM »
Fantastic, I can see clearly where it goes and locates now! Good man!
Ken, yes your right, I made them that far apart purely so you could see when I took the photos, when the butterfly is in place you can't adjust the position of the of the rods without splitting the carbs back down.
Thanks for help and photos!
