Author Topic: k7 Pilot air screw washers  (Read 3716 times)
Offline ginger_jim
  • Anyone for a Guinness?
« on: May 19, 2015, 11:12:39 PM »
Just stripped down my carbs to replace all the gaskets and seals.  Pulled the four Pilot air screw assemblies and only number 1 carb had the washer and seal present.  Does anyone know where I can get some of the washers?  I cant understand why a PO wouldn't have put them back in?  Size is outer 5mm inner 3mm and 0.5mm wide.
Re: k7 Pilot air screw washers
« Reply #1 on: May 20, 2015, 06:31:05 AM »
Never had any luck getting those, Honda only supply them with the jets. Are you sure they aint still down the hole?
Offline ginger_jim
« Reply #2 on: May 20, 2015, 07:23:20 AM »
Well....its bloody hard to tell!  Certainly couldn't see anything.  We used a depth gauge and our readings suggested that there was nothing in the recess. Oh well....the hunt is on for tiny washers!
Offline ginger_jim
« Reply #3 on: May 20, 2015, 07:45:21 AM »
Update - found same size washers on Ebay for a radio controlled racing car clutch washers!  Had to buy a bag of 10 so if anyone ever needs any let me know!
