Author Topic: Front Brake Callipers  (Read 4151 times)
Offline Coppertop1234
  • As long as the wife is happy
« on: May 24, 2015, 07:08:09 AM »
Front new master seals fitted with new braided hoses and pads
No joy the piston is seized all the way home in the recess
Tried to move it with an air line stuck solid
Present line of thought is to soak in rust release and try airline again
Failing that I would presume attacking the piston to remove and replace
Are the 400/4 front callipers the same size?
Not tried back ones yet,but expecting the same
Any tips appreciated
Keith Snr
I Love Tinkering with Old Classics
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1962 Triumph 650 Bonneville
1972 Norton Commando
1978 Honda CB400/4
1976 CB750F1
1976 Suzuki GT750 Kettle
1978 Honda CB 750 F1
Married Life No Bikes for a while then
1975 CB Honda 400/4 Restoration
1976 Kawasaki Z650   Restoration
2002 Suzuki GSX1400
1976 Honda cb750F1  Restoration
1978 Honda cb750 F1 Restoration
1977 CB 250 Dream    Restoration
1977 CB400/4  - The last one - Restoration
Re: Front Brake Callipers
« Reply #1 on: May 24, 2015, 07:45:57 AM »
Best thing to do. If you have a master cylinder, connect it to the caliper with one of your hoses. put some brake fluid in, a quick bleed, then pump the piston out with the hydraulics (you will need a handlebar or a length of tubing to enable you to squeeze the lever). Be ready with a rag to catch the fluid when the piston pops out. Works nearly every time, you wont get it out any other way without damage. O and keep you fingers out the way as it sometimes goes with a bang.
« Reply #2 on: May 24, 2015, 11:31:16 AM »
If you remove the nozzle from a grease gun the hose will thread into the pipe fitting on the caliper a couple of threads DO NOT FORCE IT AS THEY ARE DIFFERENT then with bleed nipple in pump grease gun to force piston out----never failed yet
« Reply #3 on: May 24, 2015, 12:03:04 PM »
No, they are NOT the same as 400/4, 500/4 and 550/4. The calipers pn the F1 were also fitted to the K7 ans u,s, market automatics, so good used ones are rare and expensive, thankfully Dave Silver does an exact replica now, so all is not lost if you do damage it.
« Reply #4 on: May 24, 2015, 12:56:17 PM »
The F1 front caliper used to be like rocking horse poo to find but as has been said David Silver spares now sells a replica, here is a link to a chart that I made out a while ago on interchangeability
http://www.sohc.co.uk/index.php/topic,1562.msg1650.html#msg1650
« Reply #5 on: May 24, 2015, 02:51:20 PM »
Thanks for info all
Soaked the calliper in rust remover (B&Q) over night
Washed it clean and flushed with brake fluid several times
Eventually the piston started to move - Result
I think the key was the overnight soak, as the piston rust was minimal - not pitted or damaged in any way
Removed piston cleaned the surface with metal polish - (Autosol)
Seals were fine for now but will replace at later stage
Front calliper working fine ;D
The joy of the back calliper is still to come
Keith Snr
« Last Edit: May 24, 2015, 08:42:06 PM by Coppertop1234 »
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
