Author Topic: Float Bowl O Rings  (Read 7530 times)
Offline tom400f
Float Bowl O Rings
« on: May 28, 2015, 11:16:47 AM »
I need to replace these (but everything else about my carbs is OK). What's the best source and when I do fit them do I need to add any goo?
Tom
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Re: Float Bowl O Rings
« Reply #1 on: May 28, 2015, 12:34:55 PM »
Tom
No goo !!! and if you ask nicely Garben will sell them to you >>>  http://www.ebay.co.uk/itm/CB-350-CB-400-CB350-CB400-Four-4x-carb-revision-O-ring-set-VITON-rubber-/121649841643?pt=LH_DefaultDomain_3&hash=item1c52e545eb
Offline tom400f
« Reply #2 on: May 28, 2015, 01:00:04 PM »
Perfect thanks!
One carb is seeping from the float bowl face and I know the seals are originals so time to replace them.
Thinking about it I could also use the main jet and drain screw ones as I know they are a bit dodgy. No point asking him to split after that.
1978 CB400F2 Yellow
« Reply #3 on: May 28, 2015, 11:04:32 PM »
Perfect thanks!
Once you are in the carbs Tom, you may as well do all the seals and clean up the brass ;)
Offline tom400f
« Reply #4 on: May 29, 2015, 08:40:48 AM »
This bit:
When placing the O-ring for the float bowl sealing, first apply some glue / sealant in the corners of the groove, then place the O-ring and give it some time.  This will keep the O-ring in to place during mounting.
is what I meant by goo. He says use a little goo.
1978 CB400F2 Yellow
« Reply #5 on: May 29, 2015, 09:03:13 AM »
Hi Tom. I didn't use any 'goo'  I found the 'O' rings stayed in the groove if I warmed the rings up a bit in my hands before fitting, makes them more supple. I have had no leaks so worked for me
Offline Chris400F
« Reply #6 on: May 29, 2015, 11:45:15 AM »
I used a little 'goo' but only a little, applied with a cocktail stick. Maybe I should have borrowed Julie's hands!
If the O-ring has a tendency to escape from the groove then a little masking tape will hold it in place while the 'goo' sets or the warmth from Julie's hands dissipates.
« Reply #7 on: May 29, 2015, 12:27:15 PM »
A woman with warm hands don't believe it  ;)
« Reply #8 on: May 29, 2015, 12:58:56 PM »
 ;D ;D ;D ;D ;D Warm most of the time Paul. Bloody freezing like everyone elses when I have been on the bike. Luckily my hands are quite small, perfect for fiddling with carbs
Offline tom400f
« Reply #9 on: May 31, 2015, 11:00:41 PM »
OK.
Warm hands on the rubber.
No goo.
Got it.
1978 CB400F2 Yellow
