Author Topic: Oil pump f2  (Read 4291 times)
Offline yozzer74
Oil pump f2
« on: June 11, 2015, 12:28:28 PM »
Hi I'm wanting to service my oil pump while engine is out what should I be looking to replace
Offline martin_uk
Re: Oil pump f2
« Reply #1 on: June 11, 2015, 04:52:49 PM »
The first thing is to strip pump and assess wear/damage.
Take care when holding pump ie dont damage by clamping hard in vice  and you usually need impact driver on screws.
A hot air gun is useful on the screws housing to heat  and aid screw removal.
I have found a common problem is damage to the rotor tips.
Large seals in rotor housing/body are not available from Honda, but there is someone selling aftermarkets ones, http://www.ebay.co.uk/itm/Honda-cb750-sohc-oil-pump-oil-seal-repair-kit-/151706206379?pt=LH_DefaultDomain_3&hash=item23526500ab
Seal on rotor shaft is tricky to replace.
Stopper seal can be an issue.
Once dismantled you can see whether the rubbers parts are rock hard or still compliant.
Filter gauze on pick up is available from Honda/DSS and worth replacing if damaged on removal or rubber hardened.
Ideally replace rubber parts, but easier said than done  :)
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline yozzer74
Re: Oil pump f2
« Reply #2 on: June 11, 2015, 07:26:16 PM »
Cheers for that
