Author Topic: Couple of questions. CB500.  (Read 12815 times)
Offline Spanner1972
  • Novice bike builder.
« on: June 18, 2015, 06:26:49 PM »
Some more for gents. Sorry. Lol.
Front disc, I've found out it's 4mm thick what about overall diameter and the PCD?
The kill switch, I get what it's for but how does it actually work, wouldn't turning the ignition off have the same effect?
Once again thanks.
Re: Couple of questions. CB500.
« Reply #1 on: June 18, 2015, 06:30:37 PM »
The kill switch interrupts the 12V feed to the coils, Turning the key off does that as well, in fact it turns everything off.
« Reply #2 on: June 18, 2015, 07:17:10 PM »
Also for the fact that if involved in an accident, and the bike falls on it's left side, you cannot get to the ignition to turn it off, so the kill switch gives a quick way for someone to kill the engine and help prevent fire or blowing the engine if it starts to rev, also, if the throttle jammed open while riding it :o, far easier/safer to reach the kill switch than the ignition switch :D
« Reply #3 on: June 18, 2015, 07:19:20 PM »
And burning your hand on the exhausts trying to switch the ignition off  ;D
« Reply #4 on: June 18, 2015, 07:21:35 PM »
I thought you were going to use the Honda switchgear anyway.  Being too minimalist isn't a good idea.
Offline Spanner1972
« Reply #5 on: June 18, 2015, 07:42:23 PM »
Thanks gents. Mike, not sure yet. Weighing up pros and cons to be honest. Ordered and received lots of parts, just waiting for more and then full on into it. Having trouble finding a petrol tank that fits/looks good on the bike. As some of you know it's a bobber hardtail with a radiused top yube. Nothing fits right, they can be made to fit but they don't look right then. Hunting and surfing the big wide world web for something that fits and looks good. Any info on the disc gents would be greatly appreciated as well. Thanks.
Offline Spanner1972
« Reply #6 on: June 19, 2015, 03:13:19 PM »
Gents, any info on the front disc sizes. I'm surfing the net and getting different answers of it. There's nothing about sizes in the Haynes manual I can find. Thanks.
« Reply #7 on: June 19, 2015, 05:09:27 PM »
750 and 500 discs have the same centresd, I seem to remember the minimum thickness being on the alloy centre and without going to measur one the 750 is a bigger diameter than the 500
Offline matthewmosse
« Reply #8 on: June 19, 2015, 07:56:41 PM »
What do you need to know about front disk? I can pop out to the shed with a tape measure if required. I am pretty sure the cb500 and cb550 disk are the same, but 400 and, 650 and ones 750 are not.
Offline Spanner1972
« Reply #9 on: June 20, 2015, 09:25:48 AM »
The disc is 6mm in thickness and 11" diameter. It looks to be the correct size, not sure about the thickness though. The caliber won't go any where near it when I try to put it over the disc. Thanks.
« Reply #10 on: June 20, 2015, 04:12:45 PM »
Do you mean that the disc won't fit between the pads or that the caliper mount holds the caliper too far away from the axle
Offline Spanner1972
« Reply #11 on: June 20, 2015, 05:21:23 PM »
The disc won't fit between the pads.
« Reply #12 on: June 20, 2015, 06:50:00 PM »
That's because you've got the wrong calipers.  The older bikes had thicker discs than these new 'uns
« Reply #13 on: June 20, 2015, 07:55:58 PM »
I was going to say wrong calipers or seized piston
« Reply #14 on: June 20, 2015, 08:07:42 PM »
If the piston is the right one and is all the way back, some repro pads are too thick. Recall another member having this problem but, can't find the post.
