Author Topic: Couple of questions. CB500.  (Read 12811 times)
Offline Spanner1972
  • Novice bike builder.
Re: Couple of questions. CB500.
« Reply #15 on: June 21, 2015, 11:27:58 AM »
That's because you've got the wrong calipers.  The older bikes had thicker discs than these new 'uns
Mike, I've got a proper caliper now, eBay find. It's a proper cb500 one. What is the correct disc thickness for the disc? Thanks.
« Reply #16 on: June 21, 2015, 12:22:56 PM »
It should be in the manual
Offline Spanner1972
« Reply #17 on: June 21, 2015, 01:26:47 PM »
Doesn't t give a thickness or diameter. Looked on the tinternet and various different answer to be found.
« Reply #18 on: June 21, 2015, 02:05:48 PM »
I seem to remember 7mm but I don't know from what, so...
Offline matthewmosse
« Reply #19 on: June 21, 2015, 03:02:56 PM »
7mm sounds about right, cb500 and 550 had comparatively massivly thick disks. Is the piston right back in the caliper? Have you got the right pads and mount? I often help the pad back into the caliper body by squashing it back into the caliper with a G clamp, protecting the caliper from dammage with a few bits of wood.
Offline Spanner1972
« Reply #20 on: June 22, 2015, 02:57:21 PM »
I'll try it tonight when I get home. Nice one thanks.
« Reply #21 on: June 22, 2015, 04:15:04 PM »
Forgot to say, scrub it with a toothbrush if there is any rust or crud visable.
