Author Topic: Chrome Fork Retaining Bolts  (Read 5142 times)
Offline Coppertop1234
  • As long as the wife is happy
« on: June 19, 2015, 02:47:37 PM »
identification problem - Project 2 Forks
Keith Jnr purchased  set of F1 forks from e bay which had one of the bolts with fit into top yoke missing
Ordered replacements from DSS when they arrived they were different to what 1 needed
The chrome bolt at the top of the forks on the set which were sold as F1 screw into the station but also have thread which retains the compression spring.
The set from DSS only have an hole on the inside of the bolt No Thread
DSS checked all K Series and F Series for the part I need but no joy
It sounds like I was sold forks off some other Honda - any clues which model?
The tops of the forks legs have previously had a shroud fitted to hold the headlamp like K Series
Could be easier to source another set of front forks/
Anyone got a half decent set of F1 forks they wi to part with or swap for some F2 forks
Keith Snr
I Love Tinkering with Old Classics
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1962 Triumph 650 Bonneville
1972 Norton Commando
1978 Honda CB400/4
1976 CB750F1
1976 Suzuki GT750 Kettle
1978 Honda CB 750 F1
Married Life No Bikes for a while then
1975 CB Honda 400/4 Restoration
1976 Kawasaki Z650   Restoration
2002 Suzuki GSX1400
1976 Honda cb750F1  Restoration
1978 Honda cb750 F1 Restoration
1977 CB 250 Dream    Restoration
1977 CB400/4  - The last one - Restoration
Re: Chrome Fork Retaining Bolts
« Reply #1 on: June 19, 2015, 05:00:50 PM »
The only ones i know of that have the long retaining rod is the early 500 four and maybe the 450 twin
Offline martin_uk
« Reply #2 on: June 29, 2015, 10:46:21 AM »
My F1's do not have threads on fork caps apart from outer part to screw into stanchion.
http://www.cmsnl.com/honda-cb750f1-super-sport-1976-england_model14680/partslist/F07.html#results
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline Waggles
« Reply #3 on: July 02, 2015, 10:21:39 AM »
+1 to Martin
« Reply #4 on: July 02, 2015, 10:53:09 AM »
Qustin,
Do you have a threaded bar to screw into the top nut?
If not it don't matter either will do
If yes they are completely the wrong forks
« Reply #5 on: July 10, 2015, 06:41:03 PM »
When I bought my K2 in bits, after ordering new fork station caps I got the same caps as you - the rusty ones I had from the forks had internal thread that screwed into the central threaded bar - turns out that the forks where from a CB500F (after much research. I've since changed the whole forks to the proper later K2
