Author Topic: Which flyscreen  (Read 17679 times)
Offline Ashdowner
Which flyscreen
« on: June 20, 2015, 09:54:37 AM »
I'd like to have a flyscreen to take the drag off my body on a long run. I read the reviews and the universal ones all seem to have some problem or other when adapting them to a particular bike. Can anyone recommend a screen that they've successfully fitted to their CB550K3 with it's 8" headlight housing? I'm looking for one of a similar size to a GIVI A210 which is about 350mm x 350mm.
CB550K3, CB550K1, Yamaha Midnight Star, and CA77 in 2473 pieces (at the last count)
Re: Which flyscreen
« Reply #1 on: June 20, 2015, 09:58:29 AM »
I seem to recall that Honda used to advise NOT to fit any kind of handlebar mounted fairing or screen to the SOHC fours.:$
Offline Ashdowner
Re: Which flyscreen
« Reply #2 on: June 20, 2015, 10:02:39 AM »
Had one on a previous K3 nearly 30 years ago and it was great so don't understand why Honda would say that.
Offline petersy
Re: Which flyscreen
« Reply #3 on: June 20, 2015, 11:44:26 AM »
I put one on my CB500 in 1974 - it looked great with a large alloy tank and straight handlebars.
I also put one on my CB550 this year.  The brackets were easy to make out of aluminium strip connected to the headlamp bolts and mirror fixings. These are for 7" headlamps though.
« Last Edit: June 20, 2015, 11:49:31 AM by petersy »
Re: Which flyscreen
« Reply #4 on: June 20, 2015, 12:01:36 PM »
Possibly if they were badly fitted they could cause stability issues at speed, it was generally mentioned in the owners handbooks.
Offline Chris400F
Re: Which flyscreen
« Reply #5 on: June 20, 2015, 12:35:18 PM »
There's this one if you fancy the fairing type:
http://www.ebay.co.uk/itm/like/gs-750-Classic-motorcycle-fairing/161722347902?hlpht=true&ops=true&viphx=1&_trksid=p2050601.c100103.m2451&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20150422114059%26meid%3Dd4707a53a6ef43e2a4f399b13a4c4e09%26pid%3D100103%26rk%3D2%26rkt%3D4%26sd%3D331578401661%26clkid%3D6902968335784614654&_qi=RTM1889348
I quite fancied something like this on my 400/4 but with the indicator mounts being part of the headlamp bracket I think
there would likely be a relocation issue with the indicators. Not impossible to solve but not work I want to do right now.
Petersy - where did you get yours from? It looks the part and is for a 7" headlamp.
Offline Ashdowner
Re: Which flyscreen
« Reply #6 on: June 20, 2015, 02:07:39 PM »
No I'm looking for either a bugscreen or small touring type. I don't want to get involved in adaptations and alterations
Offline Chris400F
Re: Which flyscreen
« Reply #8 on: June 20, 2015, 02:29:24 PM »
I was going to suggest the Puig too:
http://www.bs-motoparts.com/en/wind-protection/fly-screen-puig-naked-light-smoke-i674-934-0.htm
I have just ordered one for my 400. Says it will fit headlights up to 20 cms diameter, available in various tints and colours.
They do other models too. Also quite a bit cheaper than Givi items.
Re: Which flyscreen
« Reply #9 on: June 20, 2015, 06:52:03 PM »
it fits the Katana OK.  It just fixes on using the two M10 headlamp bolts
Offline Ashdowner
Re: Which flyscreen
« Reply #10 on: June 25, 2015, 10:31:07 AM »
That's the one I was looking at actually
Offline fryerk
Re: Which flyscreen
« Reply #11 on: June 25, 2015, 10:56:27 AM »
I can recommend the Dart flyscreens. I've had one on my Bonneville for about 4 years and it really makes a difference despite the size. They fit really easily just on the headlight retaining bolts.
http://www.dartflyscreens.co.uk/products/triumph-bonneville
Offline Chris400F
Re: Which flyscreen
« Reply #12 on: June 25, 2015, 11:54:42 AM »
I have now received and fitted the Puig screen. It seems to be designed to fit an 8" (20 cms) headlamp.
As noted earlier the description says it is suitable for headlights up to 20cms diameter, and it does come with various bolts and spacers to aid fitting.
The headlamp on the 400/4 is 7" but I couldn't use the spacers supplied as that would have meant using longer headlamp mounting bolts and on
the 400 they have the reflectors fitted on the end.
I ended up getting some spacers to fit between the screen mounts and screen, with longer bolts to suit, so the mounts could be fitted using the standard
headlamp mounting bolts. A bit more fiddling than I had hoped but all sorted in the end and looks fine.
With an 8" headlamp I think you should pretty much be able to bolt straight on.
Still wondering where Petersy got his headlamp fairing from with 7" headlamp hole.
Offline petersy
Re: Which flyscreen
« Reply #13 on: June 25, 2015, 12:18:34 PM »
[/quote]
I got mine here....
http://www.ebay.co.uk/itm/CAFE-RACER-FAIRING-WITH-SCREEN-OLD-BMW-STYLE-NEW-FREE-UK-DELIVERY-/251465178842?pt=LH_DefaultDomain_3&hash=item3a8c7e1eda
Offline Chris400F
Re: Which flyscreen
« Reply #14 on: June 25, 2015, 06:16:10 PM »
Thanks Peter.
That's the type I was looking for but didn't find what I wanted, hence going for the Puig (I had a GIVI on a CB-1 I used to own and liked the look of that).
I'll keep this in mind in case I decide to change.
