Author Topic: F1 Seat Strip/Cowl Bolts  (Read 3383 times)
Offline Coppertop1234
  • As long as the wife is happy
« on: June 21, 2015, 06:51:46 AM »
When removing my seat to recover it I had problems with the bolts/studs that retain the metal band from tail pice to seat.
They were rusted and broke so I would need new to refit.
I tried to source some with no joy as the studs/Bolts seem unique to the bike.
The metal strip has a hole and track the bolts/studs fit into the hole and slide through the track to where they fit onto seat base and cowl.
After pondering for a while I decided to make my own as the only ones I found were used and bent etc
A normal 6" Nail is the same head size and flat so it will slide in the track with no problem
I bought a pack for £4.00 from B&Q and ground the bolt to size for about 1" close to the head and cut off the excess
Once ground to approximate size I used a tap and dye set to thread the ground bar and put a nut and washer on each
(if you don't have a tap and dye set they are fairly cheap and a handy tool)
I will cut excess thread off during fitting
Problem solved for £4.00
Hope this helps others out who have the same issue
Chers
Keith Snr
I Love Tinkering with Old Classics
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1962 Triumph 650 Bonneville
1972 Norton Commando
1978 Honda CB400/4
1976 CB750F1
1976 Suzuki GT750 Kettle
1978 Honda CB 750 F1
Married Life No Bikes for a while then
1975 CB Honda 400/4 Restoration
1976 Kawasaki Z650   Restoration
2002 Suzuki GSX1400
1976 Honda cb750F1  Restoration
1978 Honda cb750 F1 Restoration
1977 CB 250 Dream    Restoration
1977 CB400/4  - The last one - Restoration
