Author Topic: New member I think ?  (Read 13638 times)
Offline UK Pete
Re: New member I think ?
« Reply #15 on: July 15, 2015, 10:25:50 PM »
Great work keith, you dont waste anytime , i hope you will keep posting up pictures as you go along, i am well interested
pete
Offline captaink
  • Old racers never die. ' they just go faster '
« Reply #16 on: July 16, 2015, 05:32:29 AM »
Shocks replaced for new Hagons
CR750 Replica
Norton Manx's 1947 & 1956
Norton CS1 1930
Norton International  1934
Norton 16H 1924
Norton Model 18 1929
Norton Commando / Colorado Norton Works
Triumph 1947 GP Replica
Triumph Bonniville 1967
BSA Goldstar Daytona 1956
Harley Duo Glide 1961
The Rickman project
And the CR dick Mann replica project
Sold a few of the Bikes so only got these left
Gt40...Car I know
E type fhc 1964... Car I know
" Greedy I Know
Offline captaink
« Reply #17 on: July 16, 2015, 06:07:35 AM »
The inner seat section needed modification to fit the rear section.
The seat pad is fitted to that inner section and will be in leather
« Last Edit: July 16, 2015, 06:12:57 AM by captaink »
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Offline captaink
« Reply #18 on: July 16, 2015, 06:26:50 AM »
A Sorry looking fuel tank, this has since been shot blasted, powder coated, sealed inside and tested.
New fuel taps were ordered but there not suitable, odd thread size m16 x 1.25 male,
Although powder coated now it will be 2 pack painted to protect against the spillage of fuel. Even though it won't be seen under the fibreglass over cover
Refurbed pictures to follow
« Last Edit: July 16, 2015, 06:31:39 AM by captaink »
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Offline captaink
« Reply #19 on: July 30, 2015, 08:31:31 PM »
Update on the Rickman build.
All the nickel plating should be back by mid next week !
Picture one. Some of the engine parts are back from cleaning , now you can see the condition better, all looks ok at the moment.
Picture two Tyres are now fitted and partially built.
Picture three I have altered the seat and any redundant holes filled, it will go off to be upholstered in a week or so.
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Offline captaink
« Reply #20 on: August 01, 2015, 09:01:55 PM »
The engine is now stripped except the rods.
The bearings and crank seem in really good condition, so Im going to take some advise on it.
Originally the engine ran but smoked this looks now like the exhaust valve guides are worn, looking at the inlet and exhaust valves they appear to have the same stem diameter yet they are loose in the exhaust and snug in the inlet, this may be the normal if worn, again ill ask advise from DM Engineering and if need be they can put new guides in especially as I'm having new valve sets
All the gears seem faultless but not sure if it best to replace any bearings whilst its apart
Once the cases are cleaned I might as well get new engine studs fitted
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
« Reply #21 on: August 01, 2015, 09:45:33 PM »
What size are the valve heads? The F2 had bigger valves at a different included angle and with the lumpier cam wore out the exhaust guides for a pastime, I seem to remember that the collets and top collars were different to
Offline captaink
« Reply #22 on: August 02, 2015, 07:48:54 AM »
I'll have a look at the sizes but reading the manual both valve guides should be the same 6.6mm int. diameter so the exhaust valves guides are knackered. Hence the smoking when running.
I'm going to get these replaced with new valves and springs.
I believe the engine is in good shape but a real close inspection of everything is needed, I'm checking the cyl bores later, they look good but who knows,
It will be put back 100 percent though no bodging here mate.
Here's a tiger 500 GP engine I built last year, runs a treat,
« Last Edit: August 02, 2015, 07:51:50 AM by captaink »
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
« Reply #23 on: August 02, 2015, 07:54:30 AM »
Many years back I converted one of the 500's from mettalled rods to shells
Offline captaink
« Reply #24 on: August 02, 2015, 08:01:37 AM »
Just measured the valve dia.
Inlet 34mm
Exhaust 31mm
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Offline captaink
« Reply #25 on: August 02, 2015, 08:07:16 AM »
The 1947 tiger was originally ally rods no shells
In my engine I had thunder engineering billet rods
Cylinder And head is from the generators used in lancaster bombers. Cost a bomb and still needed £ spent them, carbs are ex works  refurbed
Runs well, quick and sounds very loud
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Offline UK Pete
« Reply #26 on: August 02, 2015, 09:28:32 AM »
Great work Keith, you certainly leave no stone unturned, who done the nickle plating of the frame, can you tell me the cost?
I am enjoying this build
pete
« Reply #27 on: August 02, 2015, 09:31:55 AM »
Those sizes make it an F2 head and explains the guide wear, try Dynoman in the US for parts he has a good rep on the US forum. The Early 500 had alloy rods with white metalled steel caps and i never knew the Lancaster connection, you learn every day
Offline captaink
« Reply #28 on: August 02, 2015, 01:35:44 PM »
Lancasters used to have electric gun turrets I'm told not hydraulic, the power was supplied by triumph, who used the standard 500 bottom end with a bigger valves head in aluminium as was the cylinder for light weight.
This set produced a few more h.p. And after the war the generators with engines were snapped up by racers for the weight and extra h.p.
There a bit rare and I had to pay 2.5k for the cyl and head and then all the refurb of them .
Honda.... Anyway by inserting a piston ring in the cylinders at three point and measuring the ring gap it was found 3 bores all equal at 12 thou and one at 13 thou.
New setup I believe is 8thou with tolerance up to 27 thou.
I'll take advise on this but it shows good cylinder to me
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Offline captaink
« Reply #29 on: August 02, 2015, 01:39:54 PM »
I think I should now be posting on project board section and not as a newbie section.
So captaink will post as rickman 750 build
Bye for now
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
