Author Topic: Ignition keys  (Read 12685 times)
Offline corromant
Ignition keys
« on: July 07, 2015, 03:35:45 PM »
Does anyone know if period keys can be obtained & where from. It would be nice to have a spare.
Conrad
Born again SOHC owner
Re: Ignition keys
« Reply #1 on: July 07, 2015, 03:53:00 PM »
The original key is a T key and if you have the number they can be found in the states. If you just want a non original key, many places will cut by the number.
Offline corromant
Re: Ignition keys
« Reply #2 on: July 07, 2015, 03:56:16 PM »
Thanks Trigger will have a bit of a google
Offline Chris400F
Re: Ignition keys
« Reply #4 on: July 10, 2015, 11:33:59 AM »
Just received a spare key for my 400/4 which I ordered having seen Trigger's post.
Just the job, works perfectly.
As the guy says in the listing, better to cut to code than to copy a worn or damaged key.
Just wish I could get a steering lock key now, but even the information that came with the bike from new only has the ignition key code.
Offline corromant
Re: Ignition keys
« Reply #5 on: July 10, 2015, 11:58:10 AM »
Mine have arrived this morning, spot on. Very helpful guy, had to send a photo of one of the keys before he confirmed he could cut it. Both keys work fine.
Thanks Trigger
Offline tom400f
Re: Ignition keys
« Reply #6 on: July 10, 2015, 12:23:48 PM »
I'm not sure these are available. You have to get a new lock and drill out the old one. Simple enough to do though: http://www.sohc.co.uk/index.php/topic,4947.0.html
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Offline Chris400F
Re: Ignition keys
« Reply #7 on: July 10, 2015, 01:10:30 PM »
Thanks Tom, that doesn't look too tricky.
Guess I should probably start by ordering a new lock then!
Re: Ignition keys
« Reply #8 on: July 10, 2015, 06:00:37 PM »
You can't buy keys for Neiman locks you have to drill it out after carefully removing the rivet and washer for reuse. Dont go berserk with the drill there is a spring on the end of the lock that comes seperate
Offline Chris400F
Re: Ignition keys
« Reply #10 on: July 10, 2015, 07:47:48 PM »
They are, but he doesn't do PayPal and I've never heard of the options he does take (IBAN or BIC).
Maybe that's because I'm not a seasoned overseas buyer!
I have ordered from here:
http://www.ebay.co.uk/itm/Handlebar-Lock-Lenkschlos-Steering-Lock-Steering-Lock-For-Honda-Kawasaki-/231388905798?pt=LH_DefaultDomain_3&hash=item35dfda8146
A bit more than Frank but still much cheaper than DS and the like.
Re: Ignition keys
« Reply #11 on: July 10, 2015, 08:42:46 PM »
Frank does Paypal !
Offline Chris400F
Re: Ignition keys
« Reply #12 on: July 11, 2015, 10:12:02 AM »
I have looked at the listing again and you're right, he does. He just says it is not his preferred method of payment due to charges.
It seemed strange, I thought if you deal on eBay then PayPal is pretty much obligatory, as a seller you factor charges in to your prices.
Still suspect many people will have no idea what IBAN and BIC are though.
You live and learn!
Re: Ignition keys
« Reply #13 on: July 11, 2015, 10:21:22 AM »
An IBAN is an International Bank Account Number. You have to bank transfer directly to that account. Bit risky online if you ask me. No protection whatsoever.
Offline Chris400F
Re: Ignition keys
« Reply #14 on: July 11, 2015, 10:32:29 AM »
PayPal sounds the way to go then.
Sellers who make the buying process more difficult don't get my custom I'm afraid.
