Author Topic: Top yoke D Washers  (Read 6205 times)
Top yoke D Washers
« on: July 12, 2015, 08:50:30 PM »
I know these D washers have been discussed on several posts before but has no one made any from dimensions off the originals? I was just going to order 2 from DS but £6 each! (so £15 posted in total). I made some up from washers for the later yokes I had on to accomadate the repo clocks, but now that I have got the original rhino horn top yoke on, don't want to risk a yoke breakage.
Anybody got any or dimensions?
Re: Top yoke D Washers
« Reply #1 on: July 12, 2015, 09:49:49 PM »
Here you go : 16mm OD, 8mm ID, 2.3mm thick and the cut away is to 14mm  ;)
« Reply #2 on: July 12, 2015, 10:06:23 PM »
Cheers Graham - l'll have go at making a pair
« Reply #3 on: July 13, 2015, 06:52:23 AM »
Made a few in my time  ;D
The last one's were made from manifold spacers at ID 8.5, OD 15.5 and 3mm thick. Took them down to 2.4 mm but, you may find some better size ones with a look about.
« Last Edit: July 13, 2015, 07:04:36 AM by Trigger »
« Reply #4 on: July 13, 2015, 07:24:33 AM »
I just measured one that's been stripped of its original coating and it measures 2.3 mm thick
« Reply #5 on: July 13, 2015, 07:43:23 AM »
Did say 2.3mm originally Ash but, the last ones I did were at 2.4mm to be on the safe side ;)
« Reply #6 on: July 13, 2015, 07:50:14 AM »
Come on you two, arguing over 4thou
« Reply #7 on: July 13, 2015, 07:54:16 AM »
4 thou is a mile in engineering these days  ;D ;D ;D
Offline csd4t
« Reply #8 on: July 13, 2015, 08:12:48 AM »
And there's millions of them thou's in an inch ;)
There is no F in cod
« Reply #9 on: July 13, 2015, 08:15:16 AM »
That's exactly what I've just ordered!
« Reply #10 on: July 14, 2015, 09:29:30 AM »
Not on a 70's Triumph it aint!!!
