clutch push-rod seal
Topic: clutch push-rod seal (Read 4688 times)
clive
SOHC Member
July 13, 2015, 09:37:58 AM »
got a oil leak from seal on push rod on left side of engine (behind clutch casing) can the seal be extracted and replaced without parting the crank case's :-\s
cb500/4, 535 virago, sunny south yorkshire, apart from floods, earthquakes
Trigger
Re: clutch push-rod seal
July 13, 2015, 09:42:31 AM »
yes it can by screwing two self tapping screws into the seal and pull it out. Check to see if the push rod as not snapped, if it has I have new ones at members discount.
clive
SOHC Member
July 13, 2015, 02:49:43 PM »
thanks for that, be a while before i get round to it.
