CB350/400
400 Four Idle Problems
Topic: 400 Four Idle Problems (Read 10070 times)
Piki
SOHC Expert
July 29, 2015, 05:00:31 PM »
Hello Folks, I need your advices....Yesterday I "run" my 400 four after one sleeping year in the garage. 4 or 5 kicks and alive again, I take a short ride and all worked perfect but when I stop in the Traffic Lights, the idle is up and I have to turn the idle screw down, where is the problem??
Thank you in advance.
mike the bike
CB400F, Royal Enfield Interceptor.
Re: 400 Four Idle Problems
July 29, 2015, 05:58:57 PM »
The petrol goes off after a few months and turns into a cough-mixturey goo that blocks jets up. Unless you drained the tank and the float bowls before you put the bike to bed, this sounds like the most likely cause.
An hour or so of stripping and cleaning should make a difference.
tom400f
July 29, 2015, 08:09:22 PM »
What product do you use Oddjob?
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Nurse Julie
July 29, 2015, 08:17:16 PM »
Hi Chaps.
I don't think it has anything to do with the petrol if it started after only a few kicks. I have the same problem with the idle on my 400/4 but I'm doing quite a few miles on her at the moment and filling up at least twice a week. I think it's the carbs that need a bit of fine tuning in my case. I also saw someone start a CB750 K6 yesterday that had been sitting idle in a coal shed for 6 years and it started after about 7 kicks on the original fuel.
mike the bike
July 29, 2015, 08:24:45 PM »
What sort of coal was the bike running on?
Nurse Julie
July 29, 2015, 08:27:03 PM »
Smokeless Mike
Johnwebley
July 29, 2015, 10:36:42 PM »
interesting thoughts,
lately a lot of the sohc have been having idling issues,
would this be linked to ethenol ?? is it making the slow running more critical?
just a thought
Piki
SOHC Expert
July 30, 2015, 01:43:47 AM »
I do no think that problem is the Fuel... Is possible that "piston slides" from the carbs , not return properly??? When the bike is on the Center Stand the idle is great.....
Lobo
Lobo
Lobo
July 30, 2015, 04:18:06 AM »
I too use a petrol 'preservative' (again, garden centre type outlet); keep the tank(s) full to minimise condensation / rust .... & to date never had a problem with any of the bikes fuel system wise.
Lobo
mike the bike
July 30, 2015, 07:09:37 AM »
Most likely the pilot jet emulsion tubes are blocked
exvalvesetdabbler
Reply #10 on:
August 13, 2015, 11:17:56 AM »
I have used fuel preservative for storage over a good few years now and more recently, regular use of one that provides protection against corrosion due to the effects of ethanol in the fuel. Currently using Miller's EPS so only time will tell if this if worthwhile. I just keep about 10ml in a small minature glass bottle in my pocket and dose the tank when topping up.
http://www.millersoils.co.uk/pdf/automotive/Ethanol%20in%20Fuel.pdf
I have also noticed that fuel mixture is a bit leaner on modern fuel , particularly since replacing emulsion tubes and main jets with new OEM parts from DS. Previously the corrosion(and probably 30 years of wear) had enlarged the top of the emulsion tube causing over rich running. My pilot air screws are currently about 1 to 1 1/4 turns out to give smooth transition when rolling on the throttle at low rpm.
Modern fuel does seem to go bad quite quickly, even if a preservative has been used some of the 'goodness' seems to be lost over storage. After winter storage, filling the carbs and then draining again is necessary to get some good fuel in them , makes starting much easier.
We certainly never had these kind of problems with 2 star fuel when I were a lad.
Dave
Piki
SOHC Expert
Reply #11 on:
August 13, 2015, 11:47:50 AM »
Great info exva!! where can I get it, I live in Spain..........could I buy it on Ebay?
Best Regards.
Chris400F
Reply #12 on:
August 13, 2015, 01:07:24 PM »
There are a number of 'fuel preservative' listings on eBay (UK) but you will pay quite a bit in postage if you order from the UK.
Probably worth looking to see if there is anything similar available closer to you.
exvalvesetdabbler
Reply #13 on:
August 13, 2015, 03:07:53 PM »
Another local source of fuel stabiliser may be anywhere people keep leasure boats, marinas, chandelrys etc , or garden machinery suppliers. Just make sure you get one specifically for ethanol blended fuels. Some of the older fuel stabilisers already have ethanol in and can make corrosion problems worse.
Stabil is another brand to look out for and seems popular with the boaty types.
http://www.goldeagle.com/product/marine-sta-bil-ethanol-fuel-treatment-stabilizer
Most of the better brands come from the US because they have had to put up with ethanol in thier fuel longer than we have here.
Dave
CB350/400
