Project Board
Rickman build
3
8
Topic: Rickman build (Read 49166 times)
captaink
Old racers never die. ' they just go faster '
SOHC Expert
Rickman build
August 02, 2015, 01:47:10 PM »
Posts moved from newbie.
Gearbox now opened up and inspected all looks good
Last Edit: August 02, 2015, 01:51:20 PM by captaink
CR750 Replica
Norton Manx's 1947 & 1956
Norton CS1 1930
Norton International 1934
Norton 16H 1924
Norton Model 18 1929
Norton Commando / Colorado Norton Works
Triumph 1947 GP Replica
Triumph Bonniville 1967
BSA Goldstar Daytona 1956
Harley Duo Glide 1961
The Rickman project
And the CR dick Mann replica project
Sold a few of the Bikes so only got these left
Gt40...Car I know
E type fhc 1964... Car I know
" Greedy I Know
captaink
SOHC Expert
Re: Rickman build
August 02, 2015, 01:48:51 PM »
Posted same picture twice above, funny
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
captaink
SOHC Expert
Re: Rickman build
August 02, 2015, 02:17:13 PM »
Hi Pete,
Frame not back from platers yet and no prices as yet, all the other nickel and chrome parts are with them as well, I'll let you know £ though.
Almost every nut and bolt is stripped now,
Found someone who has or can supply fork o rings and seal etc, stantions will go off for re Chroming and overhaul even though there not worn where it matters and the ally legs will get polished
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
captaink
SOHC Expert
Re: Rickman build
August 02, 2015, 07:30:37 PM »
I knocked up a basic engine stand, essential once it starts going back together.
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Re: Rickman build
August 03, 2015, 06:56:53 AM »
Whilst you have it apart check carefully the sides of the selector forks and the tops of the "Lumps" in the selector pin tracks(hope you understand what i mean) any wear shows in those places first
captaink
SOHC Expert
Re: Rickman build
August 03, 2015, 04:54:01 PM »
I'll give them a check over then
The head is going off for new guides and valves complete tomorrow
And the cases are already into the vapour blasters workshop after which I'm sending them up to have new APE studs fitted and a visual check over.
There going to sort out new pistons and rings.
I was advised that the gearbox bearings don't usually wear except one but might change all anyway as I get them trade cost.
I'm away for a couple of weeks, when I come back hopefully some parts will be ready
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
AshimotoK0
Mad Scientist.... more power Igor ! Ù©(̾à¹Ì®Ì®ÌƒÌ¾à¹ÌƒÌ¾)Û¶
Re: Rickman build
August 03, 2015, 05:07:13 PM »
Some bearings are grooved. Which ones do you use is it the C3 high speed type?
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.†Grace Slick, Woodstock '69 .. In the year of the Sandcast.
captaink
SOHC Expert
Re: Rickman build
August 03, 2015, 05:52:49 PM »
No idea yet but as each bearing has a number it won't be a problem
I only use top bearings no cheapies
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Re: Rickman build
August 04, 2015, 06:27:52 AM »
The gearbox bearings WILL be a problem as the grooves are not a standard size so "Normal" bearings to number won't fit
AshimotoK0
Re: Rickman build
August 04, 2015, 07:04:57 AM »
Yamiya are a good source for those bearings with grooves (e.g. CB750K0 output shaft bearing) or location holes round the outer shell. What would you use for those that look 'standard' Bryan, would it be C3 rating? and which manufacturer?
Ash
captaink
SOHC Expert
Re: Rickman build
Reply #10 on:
August 04, 2015, 08:09:12 AM »
I'll ask our bearing rep when he comes in next.
Most things can be overcome if you throw enough £ at them
Points taken though I'll re use if I have too
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Re: Rickman build
Reply #11 on:
August 04, 2015, 03:30:44 PM »
I can't remember the speed ratings for bearings, do you know offhand Ash
captaink
SOHC Expert
Re: Rickman build
Reply #12 on:
August 04, 2015, 07:14:18 PM »
While I'm waiting for parts on the rickman to come back I returned to another project I'm on.
I already have a CR 750 replica in Honda colours but I want a CR 750 in Dick Mann colours but a usable bike, like with electric start. The other one is a balls out racer and not very usable even though it's road registered.
It's early days but I have a 1977 frame with V5 in good condition, shot blasted in primer and ready for chopping about.
I have started to remove Some brackets
Early days
Last Edit: August 04, 2015, 07:16:03 PM by captaink
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
UK Pete
Re: Rickman build
Reply #13 on:
August 04, 2015, 09:01:36 PM »
mmmm, interesting, will there be a separate project thread for this one keith
pete
Link to my Diecast K0 restoration
http://www.sohc.co.uk/index.php/topic,4827.0.html
Link to sandcast restoration
http://www.sohc.co.uk/index.php/topic,6862.0.html
captaink
SOHC Expert
Re: Rickman build
Reply #14 on:
August 05, 2015, 05:40:30 PM »
I think that would be best Pete otherwise it will do my head in jumping from one to another.
Also the wife won't see it.
So let's call it the "CR 750 for road use build"
It might be a bit slower than the Rickman as there's a bit more work involved me thinks.
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
3
8
Project Board
Rickman build
