Author Topic: CB400F fork leg length  (Read 11692 times)
Offline MikeSB6
« on: August 04, 2015, 02:30:36 PM »
Hello Folks,
   can someone please tell me the overall fork leg length for a CB400F? That's the stanchion and slider assembled together, from the top of the stanchion tube to the middle of the axle hole when the bike is unloaded. I'm planning to build a special and want to use Italian 35mm forks for nefarious reasons of my own.
      Cheers, MikeJ
Re: CB400F fork leg length
« Reply #1 on: August 04, 2015, 02:45:13 PM »
Hi Mike
I can measure it for you from mine. Do you want the measurement with the front wheel on the ground or the bike on the centre stand with the weight off the wheel?. Taking into account that with the wheel on the ground the forks will be compressed somewhat or if on the centre stand with wheel off the ground the forks will be extended somewhat.
Julie
Offline Herr Supersport
« Reply #2 on: August 04, 2015, 04:08:37 PM »
Mike
700mm fully extended.
Hope that will help.
Daniel
[forgot, you're British: 27 9/16 inches] ;)
« Last Edit: August 04, 2015, 04:14:26 PM by Herr Supersport »
Offline Norniron
« Reply #3 on: August 04, 2015, 07:36:35 PM »
Mike
Daniel
I second this Herr
Youre gonna need new yokes or hone your 33mm ones out though!
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline MikeSB6
« Reply #4 on: August 04, 2015, 07:45:07 PM »
Hello,
  wow! that was quick! Thanks for all the replies. I was planning to use CB550 yokes to take the fork legs. Now, what's 35mm in imperial?
     Cheers, MikeJ
Offline Chris400F
« Reply #5 on: August 04, 2015, 08:00:35 PM »
If you really want to know .... 1.37795", that's 1 3/8" plus about 3 thou .... bet you wish you hadn't asked.
Offline Norniron
« Reply #6 on: August 04, 2015, 09:12:08 PM »
Hello,
     Cheers, MikeJ
I done the same but it wasnt a straight swap.i had to get handy with the grinder to the headstock
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline MikeSB6
« Reply #7 on: August 05, 2015, 10:36:59 AM »
EEK!, what did you have to grind off?
  Cheers, MikeJ
Offline Norniron
« Reply #8 on: August 05, 2015, 08:39:25 PM »
I found the 550 stem on the btm yoke was shorter than the 400.i had to grind a bit off the bottom of the headstock to gain enough thread at the top.
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline MikeSB6
« Reply #9 on: August 06, 2015, 04:17:17 PM »
O.K., thanks Noriron, I'll keep an eye out for that when the time comes,
    Cheers, MikeJ
Offline MikeSB6
« Reply #10 on: September 14, 2015, 05:44:37 PM »
Hello again,
  weirdly, the CB550 yokes put the fork legs closer together than the 400F, so I wouldn't be able to use the wheel I want. Does anyone know if a set of CB750 yokes would fit, and what the leg spacing and diameter dimensions would be?
   Cheers, MikeJ
Offline Norniron
« Reply #11 on: September 14, 2015, 10:11:50 PM »
They cant be 550 yokes then mike!
550 yokes definately are wider than 400s
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline Norniron
« Reply #12 on: September 14, 2015, 10:18:10 PM »
Just double checked there and centre to centre the 550 is 10mm wider
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline MikeSB6
« Reply #13 on: September 17, 2015, 08:13:29 PM »
Hello there, thanks for checking- I don't know if the yokes I have are for a CB550F maybe? I don't know if they're different. Anyway, I've got a set of 750 yokes which will fit with a bit of finagling,
   Cheers, MikeJ
« Last Edit: September 17, 2015, 08:15:09 PM by MikeSB6 »
Offline Norniron
« Reply #14 on: September 17, 2015, 08:59:33 PM »
Put up some pictures Mike!
1977 400 cafe
1972 500/4
2013 triumph STR675
