Author Topic: 2 pack paint on engine.  (Read 5489 times)
Offline yozzer74
« on: August 07, 2015, 10:28:41 AM »
Hi has anyone used 2 pack paint on there engine .I was going to get the barrels powder coated .but the guy at shop says 2 pack paint can be used.and will give better gloss finish??.than powder coat .
Re: 2 pack paint on engine.
« Reply #1 on: August 07, 2015, 10:48:27 AM »
2 pack is no good on a engine. You need a VHT paint, look up US Automotive, in Bedford, they do a full range of VHT engine paint (even shocking pink)  ;D ;D ;D
LINK>> http://www.ebay.co.uk/itm/VHT-GLOSS-BLACK-ENGINE-ENAMEL-PAINT-SP124-/351177183419?hash=item51c3ca90bb
Result from SP124
« Last Edit: August 07, 2015, 10:55:11 AM by Trigger »
Offline tom400f
« Reply #2 on: August 07, 2015, 11:45:39 AM »
How many cans of prep/paint for that Trig?
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Offline yozzer74
« Reply #3 on: August 07, 2015, 02:24:42 PM »
Cheers that looks well .
Offline yozzer74
« Reply #4 on: August 07, 2015, 02:49:32 PM »
Did you use the primer and clear coat on that trig
« Reply #5 on: August 07, 2015, 03:41:50 PM »
The engine was done with 2 cans. No, primer needed, super clean surface ( any oil in the alloy will lift the paint) Bake in the oven for an hour after clean, the heat will bleed any oil out of the alloy. Clean it down with thinners/carb cleaner. No clear coat needed, and apply thin coats every half an hour, leave for 24 hours to dry and pop it in the oven to cure the paint. Once paint is cured it becomes fuel/chemical resistant  ;)
« Reply #6 on: August 08, 2015, 11:08:00 AM »
Nice finish on that Yamaha Trig. How did it stand up to everyday use?
Used the same paint on my F2 and everytime it gets a heat cycle a bit chips off the end of the fins (not a problem on the yam I know). Touched them back in with smooth Hammerite and it seems to be lasting. Cant see the touch ups either.
« Reply #7 on: August 08, 2015, 02:00:14 PM »
It is in a drag bike that runs NOS, so the engine gets very hot 8)
